Belt adjustment
It works much better on a Jack. If all you are doing is adjusting the belt? Do yourself a favor, Don't loosen the axle nut all the way. Loosen it a little to maybe 40 ft lbs. Rotate the left side welded nut clockwise very slightly. It only takes a very small movement. Check the belt tension. If everything is ok, re-torque to 100 ft lbs. If you go too far, loosen everything up and start over.
I do it this way and my right side cam does not move when I do the final torque to 100 ft lbs.!!!
I do it this way and my right side cam does not move!!!
You dont know what he is saying. When you tighten the one side wiggles around out of adjustment. At times its difficult to keep both sides the same.
Having dealt with the cam adjusters since 2008 (Road King) I think the screw jack arrangement would be better, I don't like the cam/axle system. Not having ever had the other system I can't make a fair comparison. Once you make your first adjustment, let us know which system you believe is more user friendly. I suspect that to change the adjustment system would require a swing arm replacement.
