2010-2012 VS Pre Head Pipe Stock Exhaust
Can anyone tell me the difference in the New "Stock Pipes" for the Bikes with a Cat in the head pipe vs the Older Pre-Cat head pipe "Stock Pipes"
I have a set of Slash up pipes from my old 2006 Road King was thinking of installing them since I am in the middle of a de-catted head pipe install and air kit and fuel pak.
I have a set of modified stock exhaust gotten from a friend. They sound ok but I like the slash up looks.
Reguards.
Frank
Reguards.
Frank
It can be generally assumed that "non cat" mufflers are MORE restrictive than the mufflers for bikes with cats.
as the cat is in itself a restriction to flow and sound waves
for example the "complaint for 2010+" Screaming Eagle Nightsticks are way loud on a 2009 49 State which has no cat.
slip on muffler fitment is often referred to as "1995 and up", a header flanged changed into 1995, diameter is the same-
pre 1995 mufflers will slip on to later header pipes
as noted above header fitment depends on model and year
Mike
Mike
some mufflers have cats in them- usually CA bikes.
the 09 CA moved the cat to the headers ( and some CA spec bikes are stocked and sold in bordering States-the vin will indicate a CA spec bike).
and 2010 50 state bikes also have the cat in the header, although a different design than the 09 CA header
mike
mike
Mike
Mike
I put 2009 mufflers on a 2010 RKC because I was actually trying to get quieter than stock and it did what I wanted. The 2010 mufflers look completely different on the inside, at least the right side and they are a lot louder than the 2009. A few months ago I met a guy with a stock 2010 and we compared them side by side revving them sitting still. Mine was twice as quiet.
Ok then I should be good then. My 2006 RKC was bought here in CT and I removed the Slash up stock mufflers.
Hmmmm maybe I will try them on my newly De-catted 2012 and see how they sound. The American Custom modified stock pipes are loud and now with the de-catted head pipe I bet they will be too loud for my liking.
Mr.Softy
13
06-25-2015 02:55 PM
Port Dawg
06-10-2012 04:25 PM
