New 2014 touring cam grind values
understand
Understand the numbers, and determine if I want to change cams or not. I am a two up low to mid rpm rider, these cams are pretty darn good for stock.
Several of the guys around here have put Fat Cat 2 in 1 and high flow and good tune on and they do very well. They have a slight lope at idle and respond real quick. That may be the higher speed processor in the BCM/ECM. The VE numbers when tuning are about the same as a SE 204 or TW222. They are very different to the SE255. The 255 numbers are much more similar to the stock pre 14 numbers. They will respond real well to other performance cams as well. Even the over looked SE 204 will make a good improvement. The stock 14 cams from what I have seen have .495 lift and it must be true cause I read it on the internet. The stock 9.8 compression picks them up some also.
