Best way to raise the Handlebars
I went with the HD 2 inch Pull Back Bars. It solved all my problems for hands going numb and upper back pain from reaching to far forward.
I did it myself because the dealer wanted 7 to 8 hours of labor. They say you can use the stock clutch & brake cable but I found that you only need the extended length clutch cable.
if you haven't yet, try rotating the bars to find a more comfy position.
ign. switch and lower dash panel off
big thick towel over the tank
loosen the 2 pinch bolts for the clamps
and rotate the bars
if you find a more comfy position, lock it down.
ensure that you have at least 3/8" clearance between controls and tank at full lock
if you decide to loosen or remove the controls at any time, you want to refer to the manual. a shim needs to be used or the front brake light switch will break
mike
and rotate the bars
mike
AuroraTom (08-16-2022)
bikerjenna
03-20-2011 04:45 AM
