Can't get the legs in the triple tree...
Doing a chrome lower exchange on a 05 Electra Glide Classic
Can't get the legs to line up with the top triple tree. We had a hard time getting the fork tube cap out and used the lower triple tree as a vice to remove it....think we bent something? What's the fix?
No. You would have to loosen that, then loosen the actual adjuster under the top tree to loosen the stem. Can you use a rubber mallet or a rubber dead blow hammer to tap the lower tree back into alignment with the upper while bracing the top so it doesn't move?
I don't know about that. I can't imagine just pulling them back into alignment without loosing any of the triple tree bolts
EasternSP
05-12-2011 12:55 AM
johnwwwatson
10-13-2008 03:11 AM
PoBoyGlide
02-11-2008 11:44 AM
