Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Can't Separate Upper and Lower Forks
Old Apr 22, 2011 | 10:30 PM
EasternSP's Avatar
EasternSP
Default Can't Separate Upper and Lower Forks
I'm putting chromed lower forks on my 2006 Road Glide. I have the forks off the bike and have removed the retainer clip from on top of the seal. I have tried the slide hammer action to separate the upper and lower fork and that didn't work. I suspended the fork from a vice and used a 2X4 and sledge hammer to try and drive it off. It won't budge. I tried prying the seal out but can't dig into it with an awl or sharp screw driver.
Am I missing something that is holding the upper and lower forks together?
Old Apr 23, 2011 | 11:23 AM
Teflon Tom's Avatar
Teflon Tom
Default They do get stuck sometimes!
If you have removned the bolt from the bottom of the lower forks that hold the damper to the lower legs and the seal retaining clip the lower fork tube will slide off. The seal sometimes will hold on but it should just come off with a little slide action.
Old Apr 23, 2011 | 02:03 PM
EasternSP's Avatar
EasternSP
Thanks Tom. I forgot to remove the screw from the bottom of the fork. Good lord, I think Harley tack welded those things in place. I had to drill one of them out.
Old Apr 23, 2011 | 07:30 PM
harleydogg's Avatar
harleydogg
an impact drill with a allen socket will usuly take those right off.
Old Apr 23, 2011 | 11:16 PM
EasternSP's Avatar
EasternSP
The Allen wrench rounded the nut out so I tried an extractor but that couldn't get enough bite so I just drilled the head out.
Old May 12, 2011 | 12:55 AM
Comfortably Numb's Avatar
Comfortably Numb
Default Usually..
A decent rap on the bolt with hammer does the trick. Uh....right out of the service manual.
CN
GoGetter5832
Apr 12, 2012 05:57 PM
EasternSP
Apr 23, 2011 11:53 AM
flastreetglide
Dec 9, 2008 09:08 PM
1deuce3
Nov 15, 2006 11:39 AM
TStewart20
Jan 13, 2006 09:18 PM
