2013 Limited and True Duals
Old 07-30-2014, 07:25 PM
dhornick's Avatar
dhornick
dhornick is offline
6th Gear
Default 2013 Limited and True Duals
So I've got this 13 Limited and wanting to put Rinehart True Duals on it with the 4" Slip-ons. I'm talking to the local HD parts dept and the guy advises me against the Rinehart "classic" design headpipe because the goosneck pipe that crosses through rear of the engine compartment comes within an inche of the motorcycles Coil and will eventually melt it. Really?
I want the Classic duals because I don't really care for the Slimline duals that cross over under the bike.
Anyone have a 13 Touring bike that they've put Rinehart true duals on?
Old 07-31-2014, 12:03 AM
Scaffido's Avatar
Scaffido
Scaffido is offline
I was looking into that also. That head pipe looks like it would really heat the plug ends of that coil up. I assume it's not an issue or Rienhart wouldn't design it like that but it looked too risky for me.
Old 07-31-2014, 05:08 AM
CGLTD's Avatar
CGLTD
CGLTD is offline
I do not but I have rush dual headers.
Old 08-01-2014, 02:02 PM
Devildog0311's Avatar
Devildog0311
Devildog0311 is offline
Smile Looking good
Great looking Bikes.
Old 08-01-2014, 02:09 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
if that is an issue, have a heat shield made.
that is alot of $$$$ for pipes- I guess you really want them.
more than 1 aftermarket header didn't allow the owner to check oil or tranny without removing the header...that is the difference between a "show-bike" and a bike
Mike
Old 08-04-2014, 11:32 PM
Jetblack3's Avatar
Jetblack3
Jetblack3 is offline
There are thousands of bikes running True Duals without issue including mine.
Now that you mention this it would have been cool to shoot some temps with heat gun and see the actual difference. The stock pipes are routed further away from coil but with the cat in the pipe is generates more heat. The Duals wrap differently coming off the motor as you've probably seen which makes it more difficult to check oil and tranny, basically don't want to do it HOT. Got a digital oil cap that tells level and temp. Bike runs cooler on my legs with the Duals than stock exhaust but cant say for the coil caps ?
Old 08-04-2014, 11:42 PM
equandt's Avatar
equandt
equandt is offline
I have the Rinehart Extreme true duals on my 'RGC. They are a nice true dual set up. I don't have any heat issues and for true duals, they make good power. I like the way they look and sound as well.
You might want to check with Eastern Performance or Fuel Moto for the pipes both will give you a much better price and know what they are talking about than your HD dealer.
Attached is a picture of the Rinehart XTDs and my dyno sheet before an after the TW-222 cams. Both before and after had the Rinehart XTDs on the bike.
Good luck.
Attached Thumbnails 2013 Limited and True Duals-oostburg-20130829-00209.jpg   2013 Limited and True Duals-scan0001.jpg
Old 08-05-2014, 09:16 AM
TheShrink's Avatar
TheShrink
TheShrink is offline
It's not an issue. We have installed many of the classic style on dressers. EDIT: The bike will have to have an air cleaner and a tuner with your true dual setup.
Hayhoss
01-08-2014 10:20 PM
Hog newby
04-06-2013 07:20 AM
LKHA
01-10-2012 08:45 AM
rjlman
08-23-2011 10:09 AM
Jukebox
08-18-2009 09:40 AM
Quick Reply: 2013 Limited and True Duals
