A/c suction noise
Old 08-01-2014, 02:46 AM
ridedaddy's Avatar
ridedaddy
ridedaddy is offline
Default A/c suction noise
I recently installed a roland sands design venturi 7 ac on my 2013 sg, I'm suprised how loud it is. I actually decide against going with a heavy breather becouse of people complaining of the noise they make. Not sure my choice is any better! It's not a noise I expected to hear, a suction noise I could handle but this is more of a pulsing suction noise that is caused by the butterfly in the throttle body I believe. I think this becouse it doesn't make the noise from about 75% throttle to wide open. I'm assuming this is becouse the butterfly is no longer obstructing the airflow at that throttle. So does anyone have any expirience with a filter similar to mine? Are there others that are not as noisey? Do ventilators make this much noise? How does mine compare to a heavy breather?
Old 08-01-2014, 03:04 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
....and now you know what the stock air cleaner housing does- it is there to restrict noise emissions ( same reason H-D went to a belt).
you will hear changes in the air movement- a pulsing- this has much to do with harmonics in the intake tract and alot to do with the valves opening and closing....with performance cams the exhaust tract will also influence this.
IF the butterfly were moving around...then the rpm would be moving around too.
a butterfly valve controls air into the intake ( to which fuel is added efi or carb)
more air more rpms, less air less rpms.
the valve doesn;t just flap around passively, it actively controls the air
I use a Ness big sucker ( does the job and is less expensive at about $125) which uses the stock cover.
My thigh to the tank helps to block the noise- it also helps to keep the hot air off the motor flowing past my leg
The Ness is a good alternative if you want to change. someone will take a deal on the RS
mike
Old 08-01-2014, 05:02 AM
decencyxdefied's Avatar
decencyxdefied
decencyxdefied is offline
I have a basic stage one se set up in black I'd trade ya lol
Old 08-01-2014, 05:08 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Remember small engine class...suck/squeeze/pop/phooey...you're hearing the "suck" noise and it's good b/c this means motor's getting flow...
Old 08-01-2014, 08:50 AM
prosnowsk8er's Avatar
prosnowsk8er
prosnowsk8er is offline
My dad has the same one and ya it defiantly does not muffle the noise like the stock one, but hey, you gotta pay to play!?
Old 08-01-2014, 09:00 AM
fwb35's Avatar
fwb35
fwb35 is offline
The cams and valves are what you are hearing plus the air pulsing as everything is opening and closing, it gets louder as you add performance cams.
Old 08-01-2014, 05:17 PM
Smash's Avatar
Smash
Smash is offline
I have the RS Black Ops on my SG. First thing I thought after I started it after I put it on was...Jesus, that thing is moving some air! I kinda like the sound myself... Kinda reminds me that my bike is just sucking all my money into it!
Old 08-01-2014, 06:37 PM
petdoc94's Avatar
petdoc94
petdoc94 is offline
Talking
I am with ya Smash.....
Old 08-01-2014, 06:44 PM
Webo's Avatar
Webo
Webo is offline
I have the Ventilator and don't really notice it at all but maybe I'm just use to it. I do have a loud exhaust and I normally ride with the radio at half volume or more...lol.. But as far as hearing the air cleaner and being distracted or annoyed by it... No
Old 08-01-2014, 06:56 PM
sanman4ever's Avatar
sanman4ever
sanman4ever is offline
You won't even notice it after a while.
Quick Reply: A/c suction noise
