Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Gas fumes when garaged
Old 10-28-2014, 09:31 PM
fmgsr's Avatar
fmgsr
fmgsr is offline
Default Gas fumes when garaged
I have my garage under my house. After a nice long ride, today I did about 200 miles. I refueled around 40 miles before I got home. I put the bike inside, and went upstairs. After 45 minutes or so, I noticed a very heavy gas smell coming up. I went downstairs with a flashlight, no leaks. But heavy fumes. This isn't the first time, it has happened a few times. Ideas?
Old 10-28-2014, 10:02 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,273 Likes on 11,143 Posts
I dunno. But, my 2012 does it too. Seems to be more when I pull straight into the garage. Not as much if I stop in front of the garage and fumble for thecstarter door opener. My cure has been to leave the door open for awhile.
Old 10-29-2014, 06:38 AM
Buddy WMC's Avatar
Buddy WMC
Buddy WMC is offline
I believe that after the bike is shut off, the injectors spit a bit of raw fuel causing the odor. I have had the same issue, but have never found a fuel leak. Open the door for a couple of minutes and the odor is gone.
Old 10-29-2014, 07:54 AM
airfuel's Avatar
airfuel
airfuel is offline
Think about it.
You put 5 gallons of cold gas in a metal container and put it right on top of a very hot motor.
Motor heats gas, fumes have to go somewhere.
Old 10-29-2014, 08:15 AM
ZD's Avatar
ZD
ZD is offline
Originally Posted by airfuel
Think about it.
That does of course make sense...
However! (Don'tcha hate that word? )
I have noticed the same thing with my 2011 TG when there was no fresh fuel in the tank. Just yesterday we came back from Phx with less than 1/2 tank (I filled up hours earlier in the morning) and still got the odor. It seems to happen 100% of the time if the bike has come to steady-state temps. (IOW - If I ride the 1 mile to the mailbox and back, no odor)
I have a '99 FLSTS that has never done it, with or without a freshly filled tank... Nor has any other bike I ever owned over the past 45+ years done it.
I also leave the garage door open for a while, but I come back hours later and it still smells of gasoline.
Old 10-29-2014, 06:05 PM
azyjjk's Avatar
azyjjk
azyjjk is offline
Same thing here. We have 13 & 14 TG. Had a 2000 with Champion Kit and don't recall it was a problem.
Old 10-29-2014, 06:11 PM
Gliden's Avatar
Gliden
Gliden is offline
Normal. Drives wife nuts. Only lasts a few hours.
My theory is the air filter has some fuel in the pleats after a long run which needs to evaporate.
Stinks like gas. Lasts few hours. Then no smell till next long run.
Old 12-19-2014, 12:52 PM
470004's Avatar
470004
470004 is offline
Received 15,045 Likes on 6,219 Posts
I have the same situation with my TG and SG. Like everyone else, leave the garage open for a few minutes.
Old 12-19-2014, 01:27 PM
hvacgaspiping's Avatar
hvacgaspiping
hvacgaspiping is offline
Received 16,247 Likes on 8,381 Posts
If you have no way to exhaust the fumes from your garage, then opening the door is the best way to get rid of them. However, if you have any way to vent those fumes, you won`t smell them. Examples: gas hot water heater in the garage (fumes go out of the flue pipe), attic access ladder (pull down ladder ramp a couple of inches), exhaust fan in window.
HSTWXMAN
2014-2023 Touring Models
04-26-2017 07:41 PM
Donnybrook
05-31-2016 09:44 AM
XL Scratch
01-16-2011 08:48 PM
buffdds
Exhaust System Topics
07-14-2009 09:15 PM
Trykon
07-21-2007 10:29 PM
Quick Reply: Gas fumes when garaged
