Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Progressive Shocks For Tri Glide
Old 10-08-2015, 06:04 AM
hambone51's Avatar
hambone51
hambone51 is offline
Default Progressive Shocks For Tri Glide
Saw an ad for Progressive 444 shocks for Tri Glides. Anyone running these shocks and what do you think of them?
Old 10-08-2015, 06:45 AM
Fusionfool's Avatar
Fusionfool
Fusionfool is offline
I am not running those, but am running 416-1643A 13" and absolutely love them. I do also have the lift kit from T-glide stuff.
This combination made the Tri Glide ride so much better, the wife wished I had put these shocks on from day one.
I purchased through Amazon for $298 spring of 2014. I see now they are $400 but if you shop around I bet you could find a better deal.
Old 10-08-2015, 09:18 AM
neon65's Avatar
neon65
neon65 is offline
I installed the Progressive 444-4020B black 13" heavy duty. Put three turns preload and haven't adjusted them since install. Also mount them upside down so you can get to the adjuster if need be....Also have lift kit and ride is much better than stock!
Jim
Old 10-09-2015, 10:35 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,313 Likes on 11,158 Posts
Stupid question... Amazon only shows a picture of one shock. Is the price for one or two shocks?
BTW...I recently had the progressive springs installed in the forks. Big difference in the ride and handling...particularly at high speed on the freeway.
Old 10-10-2015, 04:48 AM
Fusionfool's Avatar
Fusionfool
The price is for a set. Not a stupid question, I thought the same when I found them much less than anywhere else so I called before ordering just to be sure. I received 2 shocks in one box.
I have not tried their front springs yet, I am holding out for the next gen mono shock. They had a nice one but discontinued it before I could get a set. Tech support said they have a new one in the works maybe ready spring of 2016.
Old 10-10-2015, 05:17 AM
Polock48's Avatar
Polock48
Polock48 is offline
I'm running the same setup on my 2014 and also love them. My cost in May 2014 was $282.00
Old 10-10-2015, 05:22 AM
Fusionfool's Avatar
Fusionfool
We run at 25 psi for two up large people, just curious where your comfort level is?
Old 10-10-2015, 11:51 AM
TriGeezer's Avatar
TriGeezer
Thanks! Yeah...I was surprised when I was trying to find the mono shock cartridge that it was not available. If the cartridge is better than just the progressive spring...they must be amazing. I'm amazed at the difference the progressive springs made. I don't understand why HD doesn't have progressively wound springs standard.
Old 10-11-2015, 07:06 AM
Polock48's Avatar
Polock48
Polock48 is offline
I do the same at 26 psi with two. I'm about 200 lbs. and she is about 158 lbs. (don't tell her I said that lol)
bakron1
04-26-2019 08:06 AM
RobV10
09-27-2012 12:11 PM
WVICEMAN
11-25-2008 01:00 PM
rgaripay
12-24-2007 08:51 AM
hogsolo16
08-22-2005 07:30 PM
Quick Reply: Progressive Shocks For Tri Glide
