V & H Oversized 450 Slip-ons and FP3
Ok so I'm an idiot and just keep confusing myself, so let's start over.
I just installed the OS 450 slip-on and downloaded the OS Slip on map that showed up for the product ID number. So now what?
Do I keep the FP3 plugged and in inside the side cover and hit auto tune every time ride?
This is all new to me .. Please help
Do you have a high flow AC too? If not, go ahead and flash the bike with the OS450 Map but you may want to autotune after that because that map includes high flow AC. Don't worry about autotune right now though..it'll possibly run a little rich and that's it. Go to the V&H website and watch the video on the FP3. It is super easy or call V&H now...they'll help you out. Let me know if you have trouble and I'll be happy to walk you through it.
Ok so negative on the high flow AC. Yea I saw that on the OS map description which was downloaded and flashed. It shows up in slot 1 I believe. The base map is in slot 0. The FP is plugged in and secured in the side panel.
I believe now just before I ride I open the app and select auto tune once it connected to the FP. This will then populate the map .. The OS map .. Run this a few times then accept the map and it will flash update then .. If I understand the process?
