Anyone using FOBO?
Old Nov 20, 2015 | 07:26 PM
  #81
hbsoldier3's Avatar
hbsoldier3
Originally Posted by ROCKOUT Rocker Products
Well, I answered my own question about whether the Fobo would send a warning over the bike speakers while streaming bluetooth from the phone. It will ONLY send the warning while streaming. I was listening to Sirius this morning from their app on my phone, bluetoothed to the bike. It kept cutting in & out... the Fobo was warning me the rear tire pressure was too high (I had set it for only 45 psi max.).
If listening to, say AM radio you get no warning. (through the speakers)
I was thinking that was the case. I like to keep my phone in the tour-pac on the charger when I ride. Quess I will just have to put it in my pocket or get a handle bar mount and plug it in to the fairing, which I do not want to do.
Thanx, for the intell
Old Nov 21, 2015 | 12:25 AM
  #82
68 XLCH's Avatar
68 XLCH
Thanks for the photos hb.
Reference the high and low pressure, is that set automatically, x number of lbs above and below or do you set the min/max?
Old Nov 21, 2015 | 12:35 AM
  #83
big papa AZ's Avatar
big papa AZ
You can manually set high and low threshold.
Old Nov 21, 2015 | 05:22 AM
  #84
2015UltraLimited's Avatar
2015UltraLimited
Second that, thanks for the photo's hb (and the input from all). I ordered a set and will install the valve stems when the tires need replacement.
Old Nov 21, 2015 | 09:25 AM
  #85
hbsoldier3's Avatar
hbsoldier3
Yes, you set the nominal pressure and the FoBo app set the high and low. In addition, you can also set the high and low to whatever you want, but the FoBo settings are fine for me. You can expect at least a 10% or more like 12-13% rise in air pressure going from hot to cold.
Old Nov 21, 2015 | 10:12 AM
  #86
bigrobtemp's Avatar
bigrobtemp
Ordered a set, looking forward to getting them
Old Nov 21, 2015 | 05:51 PM
  #87
hbsoldier3's Avatar
hbsoldier3
Ya gonna like um
Old Nov 22, 2015 | 07:53 PM
  #88
Sailrider 1's Avatar
Sailrider 1
Originally Posted by J929626
FYI.. Fobo Bike T-Valve
from Fobo Bike $48.00 each.
https://my-fobo.com/Store
from Wingstuff $14.99 each
http://wingstuff.com/products/37222-...-for-fobo-tpms
Hmm, from your link I'm seeing that they are $12.00 each from FOBO ?
Price
Quantity
Total
P002X001 T Valve - 1pc (21P-TM-VAL0009/R2)
Available 12.00 12.00
Total Price: USD 12.00
Old Nov 22, 2015 | 08:00 PM
  #89
Sailrider 1
I just ordered a set for my CVO. Anyone using them with the metal right angle valve stems ?
Old Nov 22, 2015 | 09:07 PM
  #90
GaJayhawk's Avatar
GaJayhawk
Used FOBO on my OEM valve stems until I bought new tires, and then replaced the stock valve stems with FOBO's t-valve stems. I had the new tires balanced with the t-valve and FOBO's in place.
The t-valves are a no-brainer from a convenience perspective.
