2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
After market pipes too low.
Old 05-01-2016, 07:53 PM
Cruiser1's Avatar
Cruiser1
Cruiser1 is offline
Default After market pipes too low.
I mounted Cobra Power Port Headers on my 2016 Limited. Turns out that they are too low, that is too close to the ground. I have not made any changes to the suspension, with 20 psi in the rear shocks running one up. After the installation it appeared to me that they were lower than stock. Recently in a 30 mph corner I grounded the right heat shield. I wasn't pushing that hard so this is disappointing.
On my previous Harley's the floor boards acted as the initial feelers and then the floor board support, the shiny parts never touched down.
I also compared other after market pipes and most have the same problem.
I you check the stock pipes you will see that the front and rear headers are coved together to give additional ground clearance.
Old 05-02-2016, 07:00 AM
GTK's Avatar
GTK
GTK is offline
A too common problem with these after market header pipes.
Old 05-02-2016, 07:09 AM
TcHunter's Avatar
TcHunter
TcHunter is offline
I had a set on my SGS, great exhaust headers. I could ride aggressively when solo and never scraped the bottems.
I thought they mounted a little to high, cause the upper heat shield would almost cover up my timer cover.
Are u sure you did bottom out in a driveway or riding over speed bump or something.
Old 05-02-2016, 01:13 PM
Uncle Paul's Avatar
Uncle Paul
Uncle Paul is offline
This is one of the reasons, simply decatting the stock pipes goes a long way to heat reduction and improved ridability, with no loss in cornering clearance...cheaper too.
Old 05-02-2016, 03:18 PM
Mirnldi@gmail.com's Avatar
Mirnldi@gmail.com
Mirnldi@gmail.com is offline
There's a reason the stock crossover is flat.
Old 05-02-2016, 03:55 PM
Ultraboy105's Avatar
Ultraboy105
Ultraboy105 is offline
Fuelmoto X pipe, because it fits under your stock heatshield.
Old 05-02-2016, 09:10 PM
Rustrtal's Avatar
Rustrtal
Rustrtal is offline
So does the Rush Eco Header.
Old 05-02-2016, 09:13 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
FM 2-1-2 header does not scrape, I guarantee it. De-catting a stocker is a waste of time.
Old 05-02-2016, 09:24 PM
GaJayhawk's Avatar
GaJayhawk
GaJayhawk is offline
I have RC Components PowerMax headers on a '14 Ltd. The bottom heat shield scrapes before the floor board on the right side. It is not the cross-over pipe that scrapes, rather more toward the front of the lower pipe heat shield under the floorboard. It sounded like the floor board when it happened.
A friend has S&S Power Tune headers on a '15 Road Glide Ultra. Same thing and in same place.
Both of us were on stock rear suspensions, one-up, and not loaded down.
Old 05-03-2016, 07:27 AM
30glock's Avatar
30glock
30glock is offline
Fulsac here, stock shields never bottomed out, and I'm pretty big at 265lbs
RPG485
09-01-2017 09:21 AM
jberg
03-20-2012 11:52 AM
magnum629c
08-24-2009 07:19 AM
RedlandBob
06-30-2009 07:23 PM
athasl
Exhaust System Topics
03-22-2009 12:12 PM
Quick Reply: After market pipes too low.
