2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Infotainment System Start Up
Old 05-10-2017, 12:09 PM
jwg_fltrxs's Avatar
jwg_fltrxs
jwg_fltrxs is offline
Default Infotainment System Start Up
I have a 2015 FLTRXS with the Infotainment system. Most times it works flawlessly. However, during some cool (below 45) days when I turn on the ignition switch it does not boot up. I just get the H-D bar and shield logo on the screen. None of the buttons on the sides of the screen will function. None of the handlebar control buttons will function. The only thing I can do is press my Info toggle to view the temperature. From that display I can use my Infotainment menu select button on the right handlebar control and select back. Sometimes it will show the home menu and sometimes I just get the bar and shield logo again. Power off and back on does not do a reset. After riding for 15-20 minutes I try these steps again and like magic, it all works as normal.
Anyone else have this issue and recommend a work around or solution?
Old 05-10-2017, 12:19 PM
CVO SG's Avatar
CVO SG
CVO SG is offline
That was a common issue on one of the previous updates, -2 or -3. I forget. Might do the latest update and see how it goes.
jwg_fltrxs (05-10-2017)
Old 05-10-2017, 12:36 PM
jwg_fltrxs's Avatar
jwg_fltrxs
Thanks us1fountain. Looks like v 1.21.04 is the newest. I'll fire up my thumb drive and give it a try.
Old 05-10-2017, 01:32 PM
jwg_fltrxs's Avatar
jwg_fltrxs
Update complete. Time will tell if this fixes my boot up issues.
Old 05-11-2017, 08:46 AM
68 XLCH's Avatar
68 XLCH
68 XLCH is offline
I always shut down my radio before shutting down the bike. Personally I don't like the bike starting and trying to boot the info sys at the same time. This procedure has worked with all of the updates.
Old 05-11-2017, 07:20 PM
IUOE ROB's Avatar
IUOE ROB
IUOE ROB is offline
When I learned how to drive many years ago that was one of the things they taught you, shut off all electrical accessories (wipers, lights, radio, heater, etc.) before shutting down the engine, less draw on the battery next time you startup. Not sure if it still applies in today's hi tech cars but old habits die hard...
Old 05-12-2017, 05:15 PM
leonm47's Avatar
leonm47
leonm47 is offline
I'm with you I have a 14 SGS and always shut mine down haven't a problem with the Boom yet (Knock on wood).
Old 05-12-2017, 07:30 PM
68 XLCH's Avatar
68 XLCH
68 XLCH is offline
It is old school, and logical procedure, reinforced by 45 years of flying. As you stated Rob/leon, when i am starting i want all the juice from the battery going to the starter. Recip engines and especially turbine engines a lot of fuel gets dumped into the engine and we can't afford the igniters to stop firing. Again it makes sense, but it was taught to me by my father in the old Hudson, lol.
After the engine starts and the oil pressure is up, now you can start aux stuff like the boom, passing lights, fogs etc.
badjujumatt
Audio Systems
06-30-2017 07:19 PM
REDRUMULTRA
06-15-2015 12:06 PM
Gunnysgt
09-08-2014 11:12 PM
Hedgehog
30
08-21-2014 08:46 PM
deltapapa
08-11-2014 10:54 PM
Quick Reply: Infotainment System Start Up
