Help! How to remove steering stem bearings
This guy pushed the entire stem out.
YMMV
The inner race on the steering stem must be cut off, pulled off with a puller, or the stem must be pressed out of the lower clamp using a hydraulic press.
The top inner race is loose.
The inner races must be removed from the steering neck of the frame, either with a drift (if you can get to the back side of the race), a special puller, or run a bead around the race with a welder.
Chill the stem in dry ice, heat the lower inner race to 300 degrees f. Drop the bearing on to the stem.
After the bearing goes on, keep the heat gun pointed at the bearing until the temp of the stem normalizes to prevent moisture from condensing on the bearing.
The guy in the video only did half the job (cutting corners on customers bike), do you think he charged the customer for new outer races and installation??
o it
I used an outer race changing tool. (George's or Jim's can't remember which.) Bottom race was easy. Top one sucked!
I'm about to buy a press from harbor freight cause its gonna be the same price the harley stealership is charging.
As for the races, the rushmore bikes have a notch so you can get a punch in and punch it out. Super easy. Rented a bearing race installer from autozone and got them in super easy.
