2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
hidden antenna install
Old 08-06-2015, 11:59 AM
Betteroff's Avatar
Betteroff
Betteroff is offline
Originally Posted by ShoreRider
Went to Autozone and bought a pack of vacuum caps for 4 bucks. Didn't want to remove the studs in the event I went back to original antenna
This is exactly what I did. Looks fine.
Old 08-06-2015, 01:07 PM
Bilco60's Avatar
Bilco60
Bilco60 is offline
Was thinking of doing same thing. How is the performance on the hidden antennas?
Old 08-06-2015, 01:15 PM
mavantix's Avatar
mavantix
mavantix is offline
Don't know on the CB yet, but the J&M radio one is...OK. Not as good as the stock, but it's hidden and works fine with strong signal. Nice thing about the Infotainment is it mutes the radio instead of blasting static when signal gets too weak. There is a Harley one that's amplified too, but Harley doesn't have an internal CB option. In my case, I'd rather they be hidden with the decreased reception since I use my iPhone on the Boombox mostly.
Old 08-06-2015, 06:38 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
Looks good - didn't think of taking them two apart to swap.
Originally Posted by mavantix
OK, here's pictures of the install with the Harley CB antenna stud part installed on the radio side. Looks factory clean and reversible too! For an Ultra Limited you need:
2x part # 12100023
1x part # 76000164
Old 09-12-2019, 08:46 AM
GuitarKidd's Avatar
GuitarKidd
GuitarKidd is offline
2x part # 12100023
1x part # 76000164
Sorry to resurrect an old thread, but I'm slightly confused on exactly the part numbers I need.
2016 FLHTK
I went to take off the long antennas and replace them with stubbys. However, the left side was rusted up a bit and stud snapped.
What I want to do is replace both sides with all new parts.
What are the exact part numbers I need for both sides please?
I have the parts listing but it's hard to make out the part pictures.
Old 09-12-2019, 04:29 PM
Ssitruc's Avatar
Ssitruc
Ssitruc is online now
Received 1,007 Likes on 689 Posts
Be aware the two bases come apart differently... but here's the parts I see it would take to rebuild them, less the actual antennas themselves.
Left side AM/FM antenna stuff one each
76000186 Antenna Stud $6.00
76000208 Antenna Plug Assem $7.50
76353 00 Nut $1.50
6113 washer $1.50
Right Side CB antenna stuff one each
76000164 Antenna Stud $5.50
76000165 Antenna Set Screw $1.50
76000166 Antenna Set Screw $1.50
6220W Washer $1.50
7492 Nut $1.50
If you don't have a CB, then disregard 76000166 and use a "Plug" 12100023 $1.50
Check this out http://partsfinder.onlinemicrofiche....KER%20HOUSINGS
Baeseman1
27
05-16-2017 07:46 AM
sfcmo357
10-21-2013 08:39 PM
CGretCPO
04-11-2013 09:38 AM
jerseyjeff62
01-06-2009 10:16 PM
joe98
08-31-2008 09:27 AM
Quick Reply: hidden antenna install
