Let off gas, hear screeching...
Old Aug 27, 2018 | 11:26 AM
Magnut1's Avatar
Magnut1
Default Let off gas, hear screeching...
I thought I have been hearing a tiny screech now and then. This morning, my 2014 RK 13K and I left for work, keeps in an air cond garage. Took off, went about 3 blocks, let off the gas and screech, for about 2 seconds got on it and let off the gas and screech.. not as bad.. was in 3rd gear at the time, not going real fast. Anyone have this happen. I changed tires a couple months ago and the bearings felt ok.
Old Aug 27, 2018 | 12:00 PM
piper59's Avatar
piper59
I would re check the bearings!
Old Aug 27, 2018 | 12:20 PM
chopper_man's Avatar
chopper_man
Cat in the saddle bag? LOL! I would check your belt tension.
Old Aug 27, 2018 | 12:51 PM
Tom84FXST's Avatar
Tom84FXST
I would bet your belt tension/rear wheel alignment was screwed up in the tire change
Old Aug 27, 2018 | 01:56 PM
Magnut1's Avatar
Magnut1
I changed the tires myself. and check for 1" deflection. the axle has adjusters on both sides so it is self aligning. Not to say the belt got tight, I will check that tonight. It seems to do it just when cold, I took off from lunch and it made a tiny screech about 200 yards down the road, nothing after that.
Old Aug 27, 2018 | 01:58 PM
Magnut1's Avatar
Magnut1
Oh, and another thing. I put organic brakes on during wheel change, The front ones make that cicada noise when applied, and the rear one squeals when applied hard. The other thing I noticed, is when stopping kind of hard with the front brakes at low speed, it kind of clunks like they are grabbing and there is something loose.
Old Aug 30, 2018 | 10:08 AM
Magnut1's Avatar
Magnut1
Update, It didn't do it this morning, As I rolled out the bike backwards out of the garage, the wheels felt smooth and so did the brakes. I suspect there was a tiny piece of something in the rear brake. Seems to be gone now. We will see.
Old Aug 30, 2018 | 10:15 AM
Sam2010's Avatar
Sam2010
I would be checking the brakes because the noise is gone I would not call it good.
Old Aug 30, 2018 | 11:28 AM
Magnut1's Avatar
Magnut1
Will be checking them tomorrow.
Old Aug 30, 2018 | 05:39 PM
deni's Avatar
deni
1" deflection for the rear drive belt ?
How are you measuring ?
Maybe like the teeth are ratcheting.
