2018+ Softail Models Breakout
Neutral Light
Old Feb 7, 2019 | 03:12 PM
Joexl1200c's Avatar
Joexl1200c
Default Neutral Light
2018 Low Rider, no neutral light, in neutral, hit starter nothing, pull in clutch hit starter, starts. Anybody have a clue?
Old Feb 7, 2019 | 04:23 PM
M1chael's Avatar
M1chael
Could it be a bad Nutral Indicator (P/N 33926-06B)? It's a $15 part that can be replaced if you suspect it's bad. I presume after the bike started you let out the clutch lever to confirm the transmission was actually in neutral.
On a side note, I thought you needed to pull the clutch lever to actuate the clutch switch in the clutch housing in order to start the bike.... regardless if it's in neutral or not. I guess I never tried to start my bike without the lever pulled in. I'm on a 2019 Street Bob, by the way.
Old Feb 7, 2019 | 05:19 PM
Joexl1200c's Avatar
Joexl1200c
Yeah I did verify that it was actually in neutral. Thanks for your help.
Old Feb 7, 2019 | 05:27 PM
Joexl1200c's Avatar
Joexl1200c
And no if bike is in neutral you do not have to engage clutch.
Old Feb 7, 2019 | 10:47 PM
cchuck3537's Avatar
cchuck3537
Same issue on my 18 sport glide. Neutral light will come on after riding for a bit and going into neutral though, but not before the bike is fully warmed up.
Old Feb 7, 2019 | 11:56 PM
TriGeezer's Avatar
TriGeezer
It’s in warranty, Take it to your dealer..
Old Feb 8, 2019 | 12:01 AM
Joexl1200c's Avatar
Joexl1200c
Will do!
Old Feb 15, 2019 | 07:14 PM
tx freebird's Avatar
tx freebird
By any chance, have you replaced your grips or levers? When I put slightly oversized grips on may 2018 Heritage, the clutch lever would not completely disengage the neutral switch. I had to shift to neutral every time. The dealer ordered a replacement switch under warranty which did not solve the problem My tech fixed this by installing a small shim in the lever which allow the switch to disengage. Problem solved.
Old Feb 16, 2019 | 08:10 AM
AJ88V's Avatar
AJ88V
Do you mean the clutch interlock safety switch? Pretty sure the neutral switch would be on the trans.
Old Feb 16, 2019 | 03:52 PM
fjoh's Avatar
fjoh
Hes talking about the switch at the clutch lever.
I had the same issue and I just stuck a piece of duct tape on the lever to solve the issue.
on the other hand, the OP’s issue sounds like a bad neutral switch at the Tranny. (Or bad connection)...
