Sport glide fork oil capacity
Might be too late to be of use, but the service manual says, "Fill with TYPE "E" HYDRAULIC FORK OIL until oil level matches specification from top of fork tube with spring removed. Adjust oil level to specification using fork oil level gauge." Fluid Fill Dimension: FLSB 140 mm (5.5 in)
I'd attach a pic, but it only lets me attach from a URL from some reason.
I already have put screaming eagle fork oil before I read your post...
since I could find the info at the time, i carefully measured the old oil I poured out of each fork. Then refilled it with the exact same amount of new oil.
It seems be functioning just fine.
thank you for the info.
since Ce I could find the info at the time, i carefully measured the old oil I poured out of each fork. Then refilled it with the exact same amount of new oil.
I think I’d like my front suspension to be even firmer, but it’s much better than stock now.
