2018+ Softail Models Breakout
M8 in the Dyna’s
Old Feb 26, 2019 | 06:25 AM
JONNIEROCK's Avatar
JONNIEROCK
Default M8 in the Dyna’s
A buddy of mine is looking at newer street Bob’s. Are the M8 owners of the softails having the same types of problems as the M8 touring owners are ? Sumping and tranny fluid migration into the primary come to mind. Any input would be apreciated.
Jonnierock
Old Feb 26, 2019 | 09:07 AM
708encore's Avatar
708encore
Haven’t heard of any of those issues in the M8 softail.
Old Feb 26, 2019 | 10:01 AM
Mark Faulkner's Avatar
Mark Faulkner
Only seen a couple of people claiming sumping on their Softail, but i've seen no proof. If it is happening, it's very rare.
Old Feb 26, 2019 | 10:42 AM
FatBob2018's Avatar
FatBob2018
Softails are immune to the transmission fluid transfer issue; that one happens only on Touring bikes. Touring bikes have a hydraulic clutch, Softails don't.
Old Feb 26, 2019 | 01:29 PM
Buster217's Avatar
Buster217
Your buddy will be disappointed if he thinks he's going to get a Dyna with an M8.
Old Feb 26, 2019 | 02:08 PM
Yamaharley's Avatar
Yamaharley
Is there an actual physical difference between the m8 used in the softail and the m8 used in the touring? If not then yes its just as susceptible to sumping. I dont get why one would and not the other.
Old Feb 26, 2019 | 02:10 PM
uncle kebo's Avatar
uncle kebo
Lets put it this way
My 17 RGU has 16k on the clock and havent had a single issue
My 18 FB114 hasnt had a single issue
Old Feb 26, 2019 | 04:18 PM
FatBob2018's Avatar
FatBob2018
Yes there are differences. The Softail version has two counterbalancers, the Touring version has one. That difference in the crankcase may (or may not) make some difference in pressures and flow.
The Softail version is oil-cooled only, the Touring ones come in oil-cooled or twin-cooled. That means different oil pumps at least, and who knows what other issues may arise because of those differences.
Perhaps not the smallest difference is that the engine is hauling around a 650lb bike, instead of a 950lb touring bike, so it doesn't have to work nearly as hard in the Softail, which may explain some resistance to sumping even if everything else was equal.
Old Feb 26, 2019 | 06:44 PM
OldMike's Avatar
OldMike
Jonnierock
I notice there is less talk on the Softail pages about heat issues, buffeting issues and terrible ride issues.
I just switched from a touring bike to new Softail and very happy.
Old Feb 26, 2019 | 08:49 PM
AJ88V's Avatar
AJ88V
The word on the sumping issue is that it was primarily with the 114 motors and especially the motors that had all the other performance upgrades (Stage III and Stage IV) and were typically run hard at high rpm for lots of the time. Even there, it was a somewhat rare occurrence.
In mid 2017 production, HD upgraded the oil pump in all the M8 engines and this has pretty much cured the issue, period. This would cover just about all the Softail lineup which launched in 2018 with early production starting in late 2017. Some people are even doing 124" kits from S&S and not reporting issues with the new oil pump.
I'm still having trouble figuring out how the hydraulic clutch could have anything to do with it. IIRC, the Touring engines have an overflow passage to the trans so that if the sumping occurred, it transferred some of that fluid into the transmission - a reasonable place to catch it rather than dump it into the air intake since the same oil is good in both the engine and transmission and the amount of fluid transferred by sumping was observed to be small in the engine test program. That might explain why some might think the hydraulic clutch could have something to do with it. Will look for the service bulletin and update this post if I find out different than the above.
UPDATE: The TSB is M1450. I couldn't find a PDF of this, but someone photographed it and posted it in number 7 of this thread
https://www.hdforums.com/forum/milwa...tin-m1450.html
I also entered my VIN for my 2019 Low Rider in the HD website and it came back with no Service Bulletins at this time.
