Adjusting rear brake pedal height
The rear brake pedal on my Low Rider was set very low from the factory, making me move my foot to put any real pressure on it. I raised my pedal yesterday - MUCH better!!!
Others have mentioned it before, but I thought I'd write up a little tutorial for anybody else who would like to adjust their pedal height. See pic below.
NOTE: These instructions are for bikes with mid-mounted pegs. I'm not sure of the orientation of the master cylinder and pedals for the forward pegs, so use your common sense.
Ride safe!
- The brake master cylinder is mounted at the front lower corner of the frame
- You may want to measure the height of you pedal before you start if you're **** about stuff like that.
- Loosen the lock nut by turning the top of the nut towards you. If you want to raise your pedal, rotate just enough so you can turn the nut by hand.
- Remove the pin retaining ring on the back of the pin. I thought it was a hitch pin clip and ended up bending the crap out of it. This clip is like a small ring for keys, so maybe you can be more careful.
- Remove the pin. I dropped mine and, after searching the floor, found it down in the foot peg bracket in a nice little well that made it hard to see.
- Lift the clevis free of the pedal link
- To raise the pedal, turn the clevis so it moves away from the master cylinder (turn the top of the clevis away from you). I did about 5 full turns, leaving about 1/4" of pushrod still sticking out inside the clevis. (less threads showing inside the clevis, higher pedal // more threads inside, lower pedal)
- Align the clevis with the hole in the pedal link and reinstall the pin.
- Sit on the bike and see if you like the new pedal position.
- If you're happy with it, reinstall the ring.
- Tighten the lock nut.
Ride safe!
The following 20 users liked this post by AJ88V:
2018 lowrider M8 (09-19-2020),
708encore (04-09-2019),
Bayou FLHR-M8-128" (09-06-2020),
bmedeiros678 (10-27-2021),
Dan Brunet (08-15-2019),
and 15 others liked this post.
The following 2 users liked this post by AJ88V:
Reece Cofer (02-02-2020)
Since it came up in another forum, adding this amendment to the instruction:
Adding to that, the pushrod should straighten out as you press the brake pedal, applying more direct force to the MC piston. I unscientifically determined that leaving about 1/4" of thread showing in the cleavis (step 7 above) puts the pushrod at an acceptable angle.
One thing I noticed is that when you back the clevis away from the MC, it angles the pushrod significantly (because the pushrod is very short and the diameter of the pivot link is fairly small). I might have raised my pedal further except for this.
The ideal would be an adjustable lower brake arm rod with a turnbuckle in the middle. You know, the way Japanese bikes do it (with a rod only about 7 or 8 mm in diameter instead of Harley's 3/4" thick rod! LOL!)
I'm going to give this a try this weekend, maybe I can get back to using my rear brake after this adjustment.
XXTHESANDMANXX (04-11-2019)
I am looking at buying a 2019 Low Rider and noticed the same problem just sitting on the bike in the showroom. Dealer gave me a story that it wouldn't be a problem and if it was that the foot peddle could be raised, but weren't sure how. I checked around and found out this is a common problem for most people. Your DIY tip is most helpful--THANKS. If after the test ride I decide to buy it, I will make dealer make the adjustment before delivery. With the concentration of dealerships in large corporate hands, more glitz in the dealerships, but the buying experience is just like buying a car--let the buyer beware and be prepared to check everything you are told.
