I want to check the alignment of my 2019 Sportglide using the string or straight edge method. I have been told that on some Harley models the front wheel is offset from center. Do any of you know if this is the case on the Sportglide and if so, what is the amount of offset?
I can set the front parallel to the back but if the dimensions from the back tire line to the front tire are different from one side to the other, I won't know if it is because of misalignment or an offset.
