2018+ Softail Models Breakout
V&H FP4 tuner?
Old Nov 1, 2022 | 02:08 PM
  #51
Durham man's Avatar
Durham man
Originally Posted by DocHemi
Curious why you say that??? I have changed cam from stock twice, and no problems flashing it and tweaking it with the FP3
If you are happy with the way your bike runs good for you.
Old Nov 1, 2022 | 03:19 PM
  #52
izzyryder's Avatar
izzyryder
Originally Posted by FatBob2018
An interesting case where a fact can be true and simultaneously misleading. Android's worldwide market share is more like 84% of all phones globally; Apple has a 16% market share. Samsung has the largest share of the global market, at around 28% of all phones bought worldwide.
BUT: in the USA, it's very different. Apple has 54% market share of the US market. And that's probably the far more important statistic here, assuming (yes, ASSuming) that the primary audience for FP4's is USA buyers.
How they can be having such struggles with the app are puzzling; I had an FP3 back in 2015 and everything about it just worked perfectly. Don't know why things are so bad with the FP4.
The FP3 was great, but I"m guessing (guessing from the limited information I've been told) with the FP4 it was just a matter of patent expiration and licensing issues and a lack of any competent management oversight on application development. If the whole idea in using a product is synergy with a mobile application that you advertise for, then it needs to properly work when launched.
The irony is they actually already HAD the tools in place to make it a great product. If they had simply opened up the web portal interface (that they only allow for professional shops) to it's end users, then the end user could simply have chosen a map, edit/customized, etc. then send that map via cloud to the FP4 to pull up and then flash.
Basically how a Power Vision 4 works right now.
They could have continued app development in the background while allowing customers to use a website interface that was already there, giving the product workable scale to use.
Old Jul 7, 2025 | 09:43 AM
  #53
mopower440's Avatar
mopower440
6th Gear
I know this is an old thread, but i just got an FP4 and the autotune will not apply the learned values..fails every time even after deleting and re-downloading the app. any ideas?
Old Jul 7, 2025 | 10:27 AM
  #54
1HD1C's Avatar
1HD1C
unfortunately you got screwed... FP4 is GARBAGE and doesnt hold a candle to the previous FP3
mine is an expensive paperweight so cross your fingers that it doesnt brick your BCM as you try to make it work
on your bike...
personally i gave up and will be going with fuelmoto probably next tax refund season
Kyle Washam
Jan 16, 2019 11:57 PM
Wghussey
May 8, 2015 10:44 AM
Rus103
Feb 16, 2014 09:30 AM
jmoore9
Apr 20, 2011 09:56 PM
NMNSG08
Feb 15, 2011 04:28 PM
