2018+ Softail Models Breakout
Definitely a Problem, Huston….
Old Oct 13, 2022 | 07:54 PM
Phil McGrath's Avatar
Phil McGrath
Default Definitely a Problem, Huston….
Normal ride into work this morning, no hooniganning around just a nice mellow roll in. Lunch time comes up and a quick hop up too the burrito getting place, I have lunch and roll back too work. On the way back too work Im getting as best as I can describe it is what sounds like a crack-clunk sound at about 18/2000rpm I can feel it through bars and the tank. As the rev’s increase the sound changes too a crack-crunch, so I limped into work.
Milage on bike is under 8800, I don’t ride the hair off it or rag on it for the sake of ragging on it but do get on it and get down the road once in a while.
The stealership is picking it up next Thursday, any ideas on what I can tell them other than crack-clunk-crunch. I don’t want too sound like my wife who has bionic hearing of phantom obscure noises…..
Old Oct 13, 2022 | 08:10 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
I cant take an educated guess, but It doesnt sound like a compensator blow up because when those go you lose all power.
Any mods to the engine?
Old Oct 13, 2022 | 08:15 PM
Phil McGrath
Nope, just the pipe.
Old Oct 13, 2022 | 08:36 PM
TwiZted Biker's Avatar
TwiZted Biker
Well it sounds ... expensive.
Sorry had to do that
Good luck man seriously.
Old Oct 14, 2022 | 09:40 AM
Phil McGrath
Did some digging on the forum, looks like I got a case of early comp failure.
Old Oct 14, 2022 | 09:45 AM
FranBunnyFFXII
If that's the case, DO NOT START YOUR BIKE FOR ANYTHING WHAT SO EVER.
You don't want it to pop because that would throw metal **** all over your primary.
FuelMoto USA has the Cycle-Rama compensator ramp in stock right now. They got free shipping and all that.
https://www.fuelmotousa.com/i-238991...OY%20S%20FLFBS
Replacing the comp ramp isn't to bad of a job. I did it in January.
New bolt kit, and Ramp is all you really need if the gasket is good when you pull off the primary cover.
Old Oct 14, 2022 | 10:02 AM
Hammerhead Pat's Avatar
Hammerhead Pat
1800 --2000 rpm........
Old Oct 14, 2022 | 01:40 PM
Biggzed's Avatar
Biggzed
If the comp is loose it would make the racket at idle as well. Does it only make the sound at 1800-2000rpm and above?
Zach
Old Oct 14, 2022 | 02:14 PM
Phil McGrath
Zach
Yep that’s where it starts but between my no so good hearing and the pipe I will assume yes and above.
Old Oct 15, 2022 | 02:52 AM
Glenn Gorman's Avatar
Glenn Gorman
I'll bet that this is happening on some type of a motorcycle.
