2018+ Softail Models Breakout
plug wires
Old May 4, 2023 | 09:19 PM
wannavee's Avatar
wannavee
Default plug wires
I just changed plug wires and had a heck of a time with the "center" ones but it runs. Question, if they aren't seated and if it is firing just on the kickstand side plugs would I notice? Would it throw a code?
Old May 4, 2023 | 09:42 PM
GPHDXLC's Avatar
GPHDXLC
I put in all 4 new plugs, the right side overall is a pain. I have put on 200 miles and it runs great. But I was wondering about the same thing if the 2 right boots are not all the way in, would you notice anything wrong??
Old May 4, 2023 | 10:37 PM
TriGeezer's Avatar
TriGeezer
Here’s the codes for a ‘19. Which should be close enough. I don’t see a code for lack of or weak spark. Other than coil open or short, which would not be the same.
https://www.wilkinsharley.com/--Checking-Trouble-Codes-2019-Harley-David
Old May 5, 2023 | 07:06 AM
stormin08's Avatar
stormin08
why not remove he rear tank bolt, raise it slightly and check them out
Old May 5, 2023 | 07:14 AM
martin10's Avatar
martin10
I read early on in the M8 life that people were finding the plugs under the tank to be loose. So I changed my plugs early just to see. Sure enough, the were probably only finger tight. Did you find that?
Old May 8, 2023 | 08:49 AM
GPHDXLC's Avatar
GPHDXLC
Yes I did, 2 of them was just finger tight. The other 2 was just a little tight.
Old May 11, 2023 | 07:48 PM
wannavee's Avatar
wannavee
Default I got them in!
I got them in! it's easy to "miss the hole" and end up forcing the boot down the side of the plug instead of on the plug. It looks deep enough to be seated but it's not.
Old May 12, 2023 | 01:27 PM
cwsharp's Avatar
cwsharp
FYI a high performance builder told me that the SE wires didn't work as well as the stock HD wires. That was last fall, so I don't know if his opinion has changed or not... this was on a twin cam.
Old May 13, 2023 | 06:28 PM
stormin08's Avatar
stormin08
i di have any issue installing my SE wires, it helps to lift the tank.
Rlnires
Jun 1, 2014 12:55 AM
kingjoey5000
Jun 14, 2013 01:38 PM
scorchedearthpolicy
Jul 6, 2010 08:34 PM
mississippiboy
Jan 21, 2009 10:59 AM
paintballoma
Jun 6, 2007 11:18 AM
