2018+ Softail Models Breakout
Rust/water in swing. fxlrs 22
Old Jul 8, 2023 | 06:24 PM
stormin08's Avatar
stormin08
really glad this popped up, for me...not for the OP...that parts sucks.
but as a person who CLEANS every ride, i rarely wash...or ride in rainy weather...
but i will be using a cavity wax for this and on my other rides
Old Jul 9, 2023 | 03:56 PM
Tom H's Avatar
Tom H
My FXDB has two holes in the swingarm just in front of the rear tire. At first thought they were a problem until I understood the swingarm was made that way.
I shined a light inside the holes, rusty as all get out. Grabbed my corrosion/rust preventer spay and sprayed the heck out of the holes as best I could.
Another time I had the tank off to do some work. I was looking at the front frame down tubes right at the frame neck. Didn't know that the tubes is not sealed at both ends. Rusty has heck, grabbed the spray again. Also noticed rust inside the neck to backbone flat plates where the key switch and wire go through. Grabbed the spray again.
It wouldn't be so bad if all this was painted, but it's bare metal, ready to get rusty. Go figure?????
Tom
Old Jul 9, 2023 | 05:47 PM
stormin08's Avatar
stormin08
well, it would be difficult to coat the inside, even if dipped. best they could do is a cavity wax after powder.
Old Jul 10, 2023 | 06:40 PM
natural gasser's Avatar
natural gasser
Originally Posted by 2500hdon37s
Inside of the swing arm is raw steel. moisture build up and when water gets in there from the riding in rain or washing the bike will give you those nasty little rusty water spots when the water drips out the vent holes.
I'd take a product like Corrsion-X or Fluid Film and spray it in the swing arm vent holes when it's dry. That'll keep it from rusting. I did the inside of my swing arm and frame.
Corrosion-X has a couple different kinds, which one do you suggest? Thanks.
CVO18
Jun 8, 2024 01:20 AM
STREETB0BT0NY
Apr 15, 2018 08:15 PM
naphtali5725
Jun 17, 2009 12:08 PM
psmith007
May 23, 2009 01:44 PM
Fastlane
May 18, 2008 02:09 PM
