2018+ Softail Models Breakout
Idle Speed
Old Mar 31, 2024 | 08:47 AM
rcpbob's Avatar
rcpbob
Originally Posted by GalvTexGuy
It wasn’t releasing pressure and you thought it was in a vacuum?
That may be it GalvTex. If the vented gas cap is made to allow air in to prevent a tank vacuum, it had to have been positive pressure. When I loosen the cap the first time, it may have been air blowing out. Then that is the question, What causes high positive fuel tank pressure ? I need to check TC's. Thanks all. Bob
Old Mar 31, 2024 | 08:52 AM
rcpbob's Avatar
rcpbob
Originally Posted by justcruising
A vacuum as you describe & observed in the fuel tank is not normal from my observations. I suspect the gas cap is not venting under vacuum as needed. 🍻
Btw, is EITMS enabled and also coming into play? 🤔
I've had EITMS disabled.
But, my bike since I've had it ( 1 year) does a kinda strange thing. When coming to a stop, I'm usually in second with the clutch pulled in. The bike will be at normal idle, but when the bike stops moving with the clutch pulled, the idle always surges up a couple hundred rpm's, then ramps back down to idle. Is that normal >
Old Mar 31, 2024 | 10:06 AM
GPHDXLC's Avatar
GPHDXLC
My 20 Sport Glide does that at stops just a little. Always has done it, I pay no attention to it, the bike runs great, now at 25.000 miles.
Old Mar 31, 2024 | 10:18 AM
rcpbob's Avatar
rcpbob
Originally Posted by CoolBreeze3646
Okay on the TPS reset was a easy free check.
See if there are any codes associated with the check engine light, might be a clue to what is going on.
https://www.fuelmotousa.com/p-29661-...ble-codes.html
You may be able to check the vacuum by looking under the tank and locating the vent tube.
Hey CoolBreeze, found # 7 valve, fuel. I couldn't pull air thru it at the front of the rear where hose # 19 exits. Unhooked hose # 18 at the top of # 7, and can draw air thru the valve at exit of hose # 19. I hook to hose # 18 (at the end where it had hooked to # 7 valve) that runs to the fuel tank, and cannot draw air from the fuel tank. Should I be able to draw air from the fuel tank at hose # 18 ?
Old Mar 31, 2024 | 10:23 AM
joenc's Avatar
joenc
hey rcpbob....... I have 2023 fatboy and had that idle surging issue since new.. brought it back to
dealer 3 times, complaining that it can't be right. Was told repeatedly that it's normal for newer harleys.
Posted somewhere on this forum and had several replies saying it's normal, and is a safety feature to
prevent stalling at slow speeds.
I think you can get rid of it with a tuner, at least I would hope so.
Old Mar 31, 2024 | 01:28 PM
rcpbob's Avatar
rcpbob
I have a Stage 1 tune, still have the SE PST, don't know how to remove the idle surge at stopping. Bob
Old Apr 1, 2024 | 04:39 PM
rcpbob's Avatar
rcpbob
Default Idle surge
One problem solved, kinda' long explanation to follow. l think I've found the problem of idle surging up and down (super low 100 rpm to 1800 rpm), with lots of engine knocking. A year ago when I brought the bike, it already had SE Ventilator Air Cleaner installed. So I thought I'd take the Air Cleaner apart and see if anything was wrong. Well there was a problem, Screamin' Eagle AC instructions say to remove the stock induction module support bracket (see attach). It had not been removed on the initial install, so I remove the bracket. It now idles normally, throttles up and down without knocking and trying to die. Thanks to all who gave advice.
I will have to see if the gas tank over pressure happens again. It has a vented gas cap that I believe allows air into the gas tank, which it seems to do. Can anyone check that out ?
The hose the ends up in front of the rear tire, down low near the swing arm pivot point, I think is where the overflow of gas drains, when you over fill the gas tank. If this is blocked some where, would that allow over pressure to build up as engine heat soaks the gas tank ? Any ideas ?
Again, thanks for all your help everyone. Ride On ! Bob
File Type: pdf
Brueford
21
Sep 17, 2025 05:03 PM
sangbro
May 17, 2020 11:34 AM
Jed Clampett
Milwaukee Eight (M8)
May 4, 2020 01:02 AM
RHD51
General Topics/Tech Tips
Feb 23, 2017 09:10 AM
sparerib
Jan 4, 2014 12:51 PM
