2018+ Softail Models Breakout
Rough idle
Old Feb 5, 2026 | 08:55 AM
MesquiteFLD's Avatar
MesquiteFLD
Default Rough idle
25 FXLRS 685 miles. Bike has started to idle rough, RPM varies from 780-1050. Anyone else have this issue?
1K service soon, I hope they get her running correctly.
Old Feb 5, 2026 | 09:42 AM
GalvTexGuy's Avatar
GalvTexGuy
You might try this:
Turn the ignition switch on for 10 seconds and off for 10 seconds. Do not start the engine. Repeat a total of 4 times.
Old Feb 5, 2026 | 11:59 AM
abolton89's Avatar
abolton89
Make sure the intake bolts are all snug. Might be a slight leak somewhere.
Old Feb 5, 2026 | 12:20 PM
felix27's Avatar
felix27
Maybe the parade mode got turned on. This turns off the rear cylinder to provide cooling in hot weather while idling. Check the manual how to turn that off.
Old Feb 5, 2026 | 12:54 PM
MesquiteFLD
Parade mode, could not make it function as indicated.
10 sec on off 4 times, idles normal. for now...LOL
Thx
Old Feb 5, 2026 | 04:43 PM
Heritage117James's Avatar
Heritage117James
25 Heritage 285 miles - not seen that symptom yet but thanks for the heads up. Been on the charger here on and off for a month as weather tuff here.
Ride Safe 🤙 James
Old Feb 5, 2026 | 05:33 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
My ‘23 also suffers a wandering and occasionally rough idle. I’m coming to suspect it’s related to my battery.
The battery doesn’t hold a charge well, and can struggle a bit cranking the engine over. The engine will also run roughish.
Hook up a charger and let it sit for a bit, and the engine spins over briskly, and idles smoothly.
Old Feb 5, 2026 | 05:51 PM
MesquiteFLD
EITMS seems to be the issue.
Old Feb 6, 2026 | 05:23 AM
GalvTexGuy's Avatar
GalvTexGuy
It is enabled from the factory. So, by “issue” do you mean you want it disabled, but you don’t know the procedure to disable it? If so, the procedure is in your owner’s manual. In the manual index, look for EITMS.
Old Feb 6, 2026 | 07:55 AM
MesquiteFLD
Thanks I did refer to the manual. I am going to leave it turned on.
