2024+ Center-Cooled Touring Models 2023.5+ CVO and 2024+ Road Glide/Street Glide/Street Glide Ultra Center-Cooled Gen 2 M8 Touring models
Quiet Stage I (now Stage III) Road Glide Build
Old Mar 6, 2026 | 09:27 PM
  #61
Hulkss's Avatar
Hulkss
Originally Posted by mjwebb
I haven't found the radiator grill to become excessively clogged up at any time
Same here, the grills usually have rather large holes in them. When I take a grill off, I find the tiny passages between the fins in the radiator are clogged up. This is my experience on other bikes. Maybe there is no problem to be fixed.
Ride a hundred miles of wet dirt road on the way to Alaska and let me know.
Old Mar 6, 2026 | 09:42 PM
  #62
mjwebb's Avatar
mjwebb
I guess I could have described it better, no concerns from me about the radiator fins being excessively clogged either...but, I haven't rode a hundred miles of wet dirt road on the way to Alaska and can see how that would be a major concern / problem that would need to be addressed, along with all the other stuff that would get clogged and nuts and bolts rattle loose..know someone who rode her Harley on the Dalton and to Prudhoe Bay..it took a real beating for sure..I'll pass on that adventure ride unless someone wants to let me ride their bike
Old Mar 6, 2026 | 11:45 PM
  #63
Hulkss's Avatar
Hulkss
I rode to Alaska on a 2014 Street Glide. It had the stock full size front fender and I had to add a mud flap to keep the oil cooler clear of debris. No actual dirt roads, just the typical miles and miles of unpaved road construction on that route.
I feel pretty good about my skinny front 130mm tire and fender compared to having this 180mm set up in front of the radiator!!
  #64
Andrea_73's Avatar
Andrea_73
When it rains, the original fender throws a lot of water on the feet. I hope the wrapper lifts less water.
Old Mar 6, 2026 | 11:52 PM
  #65
Hulkss's Avatar
Hulkss
I'm afraid it may not help much with that. I just installed my fender and it fit perfectly just like the photos.
Old Mar 7, 2026 | 09:09 AM
  #66
MikeSGU's Avatar
MikeSGU
Default Radiator screen
The screen is easily removed on these bikes. I have seen others slip in a smaller mesh under the stock screen.
Havent seen any heat result comparisons on it, but it stops bigger stones.
Have not done the ride to Alaska yet, we prefer paved/cement roads being two up.
It would be nice to have the longer fender if it doesn’t create more heat. Our summers in KS are toasty.
Cheers
Old Mar 23, 2026 | 11:49 PM
  #67
Hulkss's Avatar
Hulkss
My local dealer just picked up my bike to install the stage 3 122 kit, the pro high volume oil pump with cam plate, and 1275N clutch springs. The SE mufflers, ST-121 Heavy Breather air cleaner, and SE Pro Street Tuner are already on the bike. I hope this combination yields a good balance of performance and engine life for touring. I'll have two riding seasons of warranty coverage before I need to decide on an extended service plan or onto a dynamometer with TTS Mastertune.
The increase in compression ratio from 10.3 to 10.9 in this kit compliments the later cam intake close of the 511 cam which is moving from 19 to 24 degrees ABDC. I'm happy to stay below the high 11.4 to 1 compression of the 121 engines or the 11.6 to 1 of the 135 crate motor. I also like that the kit does not use adjustable push rods (a personal preference).
The SE 511 Cam lacks the valve overlap and duration of aftermarket cams in order to maintain emissions compliance. For my "Quiet" build, the low overlap does reduce intake noise and a later exhaust open limits the exhaust sound level. This cam will have a smooth idle with little "chop".
In this photo you can see the high capacity bearing in the new SE lifters (top) compared to stock:
Here's some info on the SE oil pump and cam plate:
Old Mar 24, 2026 | 05:19 AM
  #68
Slingshot383's Avatar
Slingshot383
.511 lift is still a small cam, but makes good torque, which is the real driver in a V-twin pushrod engine.
Old Mar 24, 2026 | 08:08 AM
  #69
mjwebb's Avatar
mjwebb
my SE 511 has been ordered is scheduled for install next week...I won a $525 dealership gift card jackpot at our last Chapter meeting and we get 10% off of P&A and Motorclothes so figured why not..I already have a complete SE Stage 1 so out of pocket expense is just Labor. That alone wasn't initially enough to sway me to do it, but while looking at the OEM Parts Finder I discovered that the previous 99C lifters that have been used for many many years, and were the root cause of my catastrophic engine failure in my 24 RG and those have been discontinued in all 2026 M8s, Cruiser and Touring models. Those now come with the SE High Capacity lifters as OEM. It would seem HD did that for a very specific reason, possibly too many warranty claims costing them too much engine repair / replacements. Of course the newer, since 2020, SE Lifters could still have a bad one fail similarly. But after my ordeal last year I can't trust the 99Cs. I'll ride it with just the SEPST ECM calibration first but maybe have it DYNO tuned since we have an excellent Master Tech dyno operator to take advantage of whom I have had do this last on my 2017 M8 RK with excellent results. I prefer this route over running some auto tunes.
Old Mar 24, 2026 | 09:20 AM
  #70
mjwebb's Avatar
mjwebb
It's always been my understanding that the factory 2 Year Limited Powertrain warranty and subsequent ESP coverages only apply to SE performance parts installed by dealerships within 60 days of a new bike purchase. Otherwise coverage only pertains to the Parts only warranty for 1 year. I'm getting my SE Stage 2 added now, which is 8 months after I purchased my 25 RG so not counting on it being considered OEM factory warranty covered based on the literature explanation.
EDIT: conflicting information from HD on two different descriptions
Add Accessories To Your New Ride
Harley-Davidson is offering a limited opportunity to purchase new accessories and have them installed at an authorized Harley-Davidson dealership and receive the Custom Coverage extended Limited Warranty rather than the standard one year Parts and Accessories post purchase over-the-counter warranty.
  • Limited warranty for eligible street legal Genuine Harley-Davidson Motor Parts and Genuine Harley-Davidson Motor Accessories to run concurrent with the remainder of the motorcycle's 24-month manufacturer's warranty.
  • Visit an authorized Harley-Davidson dealership within 60 days to qualify for Custom Coverage.
  • Parts and accessories must be purchased and installed at an authorized Harley-Davidson dealership to qualify for Custom Coverage.
  • Visit any authorized Harley-Davidson dealership as often as you like during the 60 days after purchase to select, purchase and install accessories.
Ride, personalize, customize. Take advantage of this Custom Coverage extended Limited Warranty offer today to make your bike your Custom ride.
NOTE
Customers have 60 days after the motorcycle purchase date to participate in Custom Coverage extended Limited Warranty offer. Parts and Accessories must be purchased and installed at an authorized Harley-Davidson dealership. Parts and Accessories purchased via the internet are not eligible. To locate the authorized Harley-Davidson dealership nearest you, visit the Dealer Locator on www.harley-davidson.com.
CUSTOM COVERAGEŽ LIMITED WARRANTY ENHANCEMENT ON STREET LEGAL GENUINE MOTOR PARTS AND STREET LEGAL GENUINE MOTOR ACCESSORIES
The Custom Coverage program enhances the limited warranty coverage on qualifying Genuine Harley-Davidson Parts and Accessories that were purchased new, installed by an Authorized Harley-Davidson Dealer and registered to a qualifying motorcycle. Purchase options for new Genuine Parts and Accessories include; a) Harley-Davidson.com E-Commerce site, b) In-Store Online Purchase in Harley-Davidson Dealership, c) Directly through an Authorized Harley-Davidson dealership. This program provides parts and labor coverage for qualifying Genuine Harley-Davidson Parts and Accessories for the remainder of the Manufacturer’s Limited Warranty on the motorcycle.
To qualify for Custom Coverage, 1) the motorcycle must be under the Manufacturer’s Limited Warranty at the time the Genuine Harley-Davidson Parts and Accessories are purchased and installed; 2) the Genuine Harley-Davidson Parts and Accessories must be installed by the authorized Harley-Davidson dealer; and 3) the Genuine Harley-Davidson Parts and Accessories must be electronically registered to the vehicle by the authorized Harley-Davidson Dealer.
1. Dealers must validate parts were purchased new for anything that wasn’t purchased directly in their dealership.
The Harley-Davidson Custom Coverage Limited Warranty Enhancement for Genuine Motor Parts and Genuine Motor Accessories will run concurrent with and for the remaining length of the motorcycle’s 24-month Manufacturer’s Limited Warranty. If the motorcycles Limited Warranty expires during the term of the Genuine Harley-Davidson Parts’ or Accessory’s P&A part warranty (1-year from purchase date), the P&A limited part warranty will still provide coverage for the remaining term of the limited part warranty but will no longer have the enhanced labor coverage.
  • Example: Daymaker headlight is installed and registered to a vehicle with 6-months remaining on the Manufacturer’s Limited Warranty, that headlight qualifies for 6 months of Custom Coverage Limited Warranty (Parts and Labor) and 6 months of standard P&A warranty (Part Only).
