Speaker question???
Old Jul 5, 2015 | 05:07 PM
bowman78's Avatar
bowman78
Default Speaker question???
So I have a road glide custom that I finally decided to do some stereo upgrades to.. Installed a Jackson Bluetooth head unit and wheel controls and added a Rockford power tm400x2ad 2 ch amp... In hindsight I think the 4 channel may have been the way to go??? Anyhow the distributor I have been dealing with originally sent me Polk db651s speakers before I had nailed down which amp I was goin with.. Was going to try and run polks with the plug and play prime 2ch kit I already had.. The polks didn't fit the 6.75 adapters I got.. So the distidutor sent me some powerbass 6.5 's to try again before I nailed down my amp selection..
Well, fast forward I installed the Rockford power amp and ran it with the powerbass speakers.. I cautiously set the gain and eq gain adjustments and set the high pass filter on the amp to approx 75 hz.. Needless to say the amp killed the speakers on a 4 hr ride.. Burned out the tweeters.. So my question is what reasonably priced 6.5-6.75 coax or component speakers can/ should I get and should I add in 2 more 6.5 in the inner fairing??? Thanks for any advice!!!
Old Jul 5, 2015 | 05:33 PM
haze324's Avatar
haze324
That amp has enough behind it to run 4 speakers in parallel.
What's your budget on speakers? Lots of good choices out there. Oh and those Polks wouldn't have stood a chance with that amp either!
Old Jul 5, 2015 | 05:49 PM
Gannicus's Avatar
Gannicus
Bowman - That distributor is 0 for 2. I'd suggest letting him go his merry way. LOL!! You got a bad *** amp! Now all you need is some bad *** speakers to match your amp. Biketronics has some really nice value line 6.5 speakers you might want to try. But if your budget permits get the Titan II speakers from Biktronics. Talk to Bill. He will take care of you!
painey
Audio Systems
May 23, 2019 02:49 PM
Fblo1690
Audio Systems
13
Dec 2, 2016 09:40 PM
Jagpanzer
Audio Systems
Oct 11, 2014 08:30 AM
nivensid
Jun 7, 2012 11:21 PM
mikebaby
Mar 8, 2012 01:49 PM
