Infotainment system totally dead
On three different occasions the infotainment on my 2014 Ultra Limited simply did not come on with the ignition switch. It also I'd not come on when the switch was in the acc position. So far it has come back to life after the bike is parked for a while. This a bit disconcerting as the issue began a month ago and has happened twice over the past week. Any ideas?
Has your radio been flashed with the latest software update?
Mine acted like that when new. One of the updates along the way stopped this issue.
You can download the software update file from the Harley site. You can do it yourself and it only takes a few minutes. Instructions on site too.
See if this stops it.
Make sure you have a good USB drive when you do it. I've had issues with the load due to a bad USB drive. Damn things can be finicky from time to time. You may also have to load more than once. I've seen posts on other forums about the download not working 100% on the first try every time.
ICEMAN-WB
2014-2024 Touring Models
Jan 31, 2015 10:10 AM
Smittyjf
May 5, 2013 04:45 PM
