Not a problem
You are going to have to set the gains to different AC volts on the out put of the amp since you are using a 2 ohm and 4 ohm speakers.
Make sure the AVC on the head unit is off also
Amp input is running from a line level box for the rca input on front speakers.
Just to make sure you'r not spending money when you don't need to. When you say "line level box" you mean a Line Out Converter that cost about 10 bucks, not a Line Leveler from BT that cost 75 bucks.
Looking at it again, I have a 2nd line output convereter.
Is there a way to use 1 output converter for lowers at 4 ohm and them use my 2nd output converter for the 2 ohm infinity and keep the rear 2 ohm tour pak speakers?
