Aswc-1 source button
Old May 3, 2016 | 02:27 PM
07flhxskull's Avatar
07flhxskull
Default Aswc-1 source button
My aswc-1 worked great on my 07 flhx. Had it working on my 2012 flhx, but had to reprogram it, and now the thyme control won't switch the source. It puts my phone into car mode instead. Got any ideas?
Old May 3, 2016 | 03:53 PM
AAWAV's Avatar
AAWAV
sorry - your message is really confusing.
is it on a bike now?
what is your head unit brand?
puts phone into car mode????
Did you run a new HU detection cycle?
did you read up on the manual in the sticky thread in the audio section?
please provide more details and we might be able to help you
Old May 4, 2016 | 12:19 AM
07flhxskull
Yes it's on the bike now.
Hu is sony bluetooth.
Read the sticky manual and programed and reset so many times inpractIy call have it memorized.
I know it's not a wiring issue, because when I push the source thumb control, it activates my note 4 phone to car mode or voice command.
Old May 10, 2016 | 11:14 PM
07flhxskull
My phone shows this when I hit the source thumb control
Old May 11, 2016 | 09:31 AM
AAWAV's Avatar
AAWAV
please provide Sony model.
looks like you got phone hardwired (usb) to HU or you using bluetooth?
sony HU might have options for Pandora app...
you tried to push Source button again after your phone shows the screen?
Old May 12, 2016 | 01:51 PM
07flhxskull
It's a sony mex-m7obt
Using bluetooth
Pushing source button a second time does nothing.
I also tried unpairing the phone and reprogramming the aswc
Old May 13, 2016 | 10:27 AM
AAWAV's Avatar
AAWAV
okay - this is what I THINK is the issue...
I quickly skimmed over the Sony manual and it supports Pandora via Phone.
try this (use the manual as a reference; I could not quickly find an option to turn off "pandora as a source".
a. turn HU on
b. UNPAIR your phone from the Sony
c. use SRC button on HU to go thru each SRC, see if they work/come up (should be like Tuner, USB, CD, etc (sequence I could not find in the manual).
d. write down the src sequence (it will go back to the first one eventually and then "loop" thru them all again
e. now use the Bike source button (right side; push)
f. check if the same sources are showing up
YOUR PHONE will NOT show (or better Bluetooth) as your phone is not paired...
if the above shows the same, the ASWC1 is NOT the issue. Sony HU (I am not familiar with them but I believe Gannicus runs one now) MUST be, if possible, configured to NOT use Pandora app... because looking at your screenshot, it is indicating to me the HU wants to start up Pandora on the phone as the next source in line after your Bluetootg SRC).
KDUBYA
Electrical/Lighting/Alarm
Mar 27, 2016 07:16 AM
Mathews2
Dec 12, 2014 10:15 PM
thenewrage
Jan 11, 2011 02:41 PM
XXXRacing
May 30, 2008 05:12 PM
swipter
Oct 3, 2007 04:12 PM
