another stupid question
Old Aug 27, 2016 | 09:39 PM
Stang951's Avatar
Stang951
Default another stupid question
Stock HK head unit, added PN4.520 amp. Do I need to stay with 2ohm speakers since I added the amp? I was going with the Inifinity 62.11I's but they are skyrocketing. Looking at cheaper options for the front.
Old Aug 27, 2016 | 09:47 PM
SBates08's Avatar
SBates08
No you can run 4ohm speakers with this amp as well. Are you doing just fairing?
Old Aug 27, 2016 | 09:50 PM
yooperhog's Avatar
yooperhog
that amp is great for a couple 4 ohm speakers as well as it can be bridged at 4 ohms as well. check the audio classifieds for some good deals on some good speakers. i havent been watching speaker prices, but the kappas have jumped quite a bit
Old Aug 27, 2016 | 09:52 PM
Stang951's Avatar
Stang951
Fairing and TP pods. Was thinking of doingd lids instead of TP pods but I dont have the scratch. The JM speakers I have now actually sound ok, but I want better.
Old Aug 27, 2016 | 09:54 PM
SBates08's Avatar
SBates08
Take a look at these. Really great sounding speakers and they really take a beating. Only thing running 4ohm with this amp you won't have any headroom.
https://www.amazon.com/Kicker-41KSC6.../dp/B00JST5H52
Old Aug 27, 2016 | 09:59 PM
Stang951's Avatar
Stang951
Meaning I wont be able to add more speakers without adding more amps correct?
SBAtes, will those fit in the pods as well?
Old Aug 27, 2016 | 10:03 PM
SBates08's Avatar
SBates08
Meaning I wont be able to add more speakers without adding more amps correct? SBAtes, will those fit in the pods as well?
Yes they fit in the pods no problem. What I mean by headroom is this, the amp is rated at 100 watts at 4ohm and those speakers will handle 100 watts RMS hence no headroom. It'll work but the amp will work harder too. If your not stuck with that amp I'd look at the SS pn4.1000 and you'll have plenty to work with.
Old Aug 27, 2016 | 10:45 PM
Stang951's Avatar
Stang951
I've had it a while. Just swapped to the Alloy Art Fairing brackets and the 520 is the limit as far as width of the amp with those brackets.
Old Aug 27, 2016 | 11:10 PM
SBates08's Avatar
SBates08
I gotcha. The 520 will still work with those speakers. May even surprise you at how well they sound.
Old Aug 28, 2016 | 09:20 PM
Stang951's Avatar
Stang951
Pulled the trigger on the Kickers and the Metra adapter for the Harleys. Speakers not in stock until 8/31 so I wont have them until next week. Stoked to hear how they sound compared to the JM's.
