Tweeter Mounting?
Old Nov 14, 2016 | 11:22 AM
No U Glider's Avatar
No U Glider
Default Tweeter Mounting?
Looking for alternatives to mounting tweeters in the grills. Please post up some pic's if you went a different route... Was thinking of area where my fairing mounted mirrors attached but hesitant to cut on the inner fairing...
Old Nov 14, 2016 | 02:50 PM
InthewindMN's Avatar
InthewindMN
Not mine but I found this online.
Old Nov 14, 2016 | 06:33 PM
paoloD's Avatar
paoloD
I have seen some kits that allow the tweeter to be mounted in the gauge holes
Old Nov 14, 2016 | 07:29 PM
tesnevo's Avatar
tesnevo
Do them in the grills brother. Easy to cut and mount. If not you will have no choice but to cut the fairing
Old Nov 14, 2016 | 08:28 PM
No U Glider
Gonna go in the grill... cheaper if I f... it up!
Old Nov 15, 2016 | 12:18 AM
Bertk's Avatar
Bertk
These are the grills you want modify to mount the tweeters.
Old Nov 15, 2016 | 04:15 PM
black01's Avatar
black01
What is used to cut the grills? Never cut a mesh grill before.
Old Nov 15, 2016 | 05:01 PM
sponger's Avatar
sponger
Hole saw. And i finished them with a dremel sanding tool.
Old Nov 15, 2016 | 05:08 PM
Tailwind's Avatar
Tailwind
Two inch dozer bit with pilot bit.
Just screw the grill face down to a thick piece of wood, and drill away in the center of the grill. Clean up sharp edges w Dremmel. I used a couple of 2x10 scraps stacked and now have a jig that works well.
Just make sure u take the tweet to lowes w u as 2" might be a touch big. I think I have 1 7/8 for focal and 2" for hertz MLK but not sure.
T
Old Nov 15, 2016 | 06:04 PM
tesnevo's Avatar
tesnevo
Huh, I use the metal CVO grills. Easy to cut with hole saw or dremmel.
