Gurus need your assistance, been running a TM400x2AD with Mille pro 165.5 in the front fairing on my FLHTK
been running good until I installed the air wing rail lights, that's when I started to get some sort of noise on my left speaker, if I switched channels the noise would be on the opposite speaker, the noise I'm possibly hearing sounds like distorting or vibrating. have ordered the BT line leveller and hope it will solve my issue but I think it could be more to it
thanks in advance
How is the amp connected to the radio. Using high-level inputs or line out converter's?
When you got a noise to shift from one channel to the other what wires did you swap? Installing the BT line levelers may help if there is a loose connection between the radio and the amp. Also check the speaker output connections on the affected side.
You will also need a pair of 18 inch RCA cables along with the line levelers.
