Cable gauge help
Old Mar 13, 2017 | 08:55 PM
Hades02's Avatar
Hades02
Default Cable gauge help
2 amps, SS PN4.1000D and Precision Power 350.2. Finally getting around to installing the PP amp. The question is do I do a 4 gauge wire to a distribution block with fuses to 8 gauge wires to the amps or do I do an 8 gauge wire to a distribution block with fuses to 8 gauge wires to the amps?
Old Mar 13, 2017 | 09:19 PM
Bunker's Avatar
Bunker
I ran 4 gauge with an inline 100amp fuse to my fairing and then run 8 gauge with 60 amp fuses from a distribution block to both my TM400x2 amps, I had run another power to the power supply on the MEX100 head unit when I was running it (1x 4 gauge in and 3x 8 gauge out distribution block)
Old Mar 13, 2017 | 09:28 PM
Bertk's Avatar
Bertk
Yes 4ga to the distribution block and a fused 8ga to each amp. If you are using two 30amp fuses at the distribution block you want a 60 amp fuse as close as possible to the battery on the 4ga. And another 4ga to a ground block and 8ga to each amp ground. Or you can use 2 8ga for power with inline fuses, and 2 8ga for ground.
Old Mar 14, 2017 | 08:56 AM
Hades02's Avatar
Hades02
Thanks for the help guys. I really appreciate it. Wanted to make sure that I was wiring it up correctly.
woodguy75
Audio Systems
Oct 30, 2018 10:43 PM
Jaxx
Audio Systems
May 18, 2016 11:25 PM
RC07ultra
Audio Systems
Nov 15, 2015 09:29 AM
redneckharley
Audio Systems
15
Nov 4, 2014 06:54 PM
No Tyme
Mar 4, 2008 04:57 PM
