I have been following a few threads where they are talking about using a DSP. but I am not sure of its total use and installation. I tried to go back and look for more info but didn't find anything that laid it out to the point where I can fully understand what you guys are talking about.
Would someone break it down for me?
Thanks
Brad
Reason: Spelling
I can break it down from a rookie's perspective. One of the pro's can fill you in on the rest. The DSP is a simple install. Same as an amp. It has inputs that come in directly from the head unit. On the Rushmore HU, there is a ton of sound processing built into it with their Boom software. The signal you get from the Boom HU is not a pure and true signal. It is one that has been massacred by Harley to make sure their speakers don't blow. The DSP takes that signal and "processes" it into a flat and pure signal. At that point, the signal you send to your amps is one that is genuine. This is where it gets tricky. There's a LOT of settings you can use to get the right tune. You are able to use your laptop to set crossovers, equalize the curve at different frequencies, increase or decrease output power to the individual channels. This portion of the DSP is what separates the men from the boys. I fall into the "boys" camp. Learning how to set the software and calibrate your system requires some knowledge and expertise. I have neither. Luckily we have dudes on this forum who are willing to help out when everything goes down the crapper.
What I can tell you is this. If you can set, or find someone to help you set the DSP calibration for your setup, it is amazing. The difference between a rookie like me trying to set it up versus someone who knows what their doing is night and day. When Slye sent me my file back to load up, it sounded like I had all new speakers and amps. When I used mine it sounded pretty crappy. So that's my .02 on what a DSP is and does. Now someone can tell him what it REALLY is and does.
A basic 4 and even some 6 speaker setup for example really would not benefit much from it, depending on the head unit etc. Once you are into pro audio, 6+ advanced speaker setups, so on the potential increases to benefit from the adjustablility. I believe it is time to bring the PSA back up again.
So yea... Just trying to understand what guys are doing and how it works. No system that really matters.
It is not just a do this and that type of deal. So much involved it is too much to explain, and no offense, spent too many years learning and doing to just give all that away and make minimal or no sense without the comprehension involved. That is why I posted a new question and answer thread I truly hope will be used and will simplify the process for all members.
Just joined in and new to the bagger game, I’m really not trying to get crazy with my music but I want to sound good and have that quality sound.. I’m interested in adding a dsp but don’t know what brand to go with does any one have a go to dsp they recommend? Thank you
You would be best starting a new thread . Include your bike model, current setup, expectations and budget and these guys will point you the right direction.
