Wiring AW's and JL MX500/4
09-01-2017, 05:42 PM
Which one of these bridged configurations do I use for the DD AW 6.5, AT28 tweets and the JL MX500/4?
09-01-2017, 07:40 PM
With the MX280/4 which is essentially the same amp only smaller, I have used the "stereo" configuration wth the Y splitters and had success.
09-02-2017, 08:42 AM
If just two speaker setup I would go stereo not much difference either way when things get more complex splitters all over the place is just a mess and takes up needed space.
09-04-2017, 10:28 AM
I have the same setup and wired it with the Stereo bridged config. I ran a test MP3 tone and stereo works as designed.
09-04-2017, 11:28 AM
Thanks for the replies. Any recommendations on cables to use? Did you run the crossover on the amp on full pass or high pass?
09-04-2017, 12:56 PM
Quote:
Originally Posted by
HD_Doobie
Hey brother....these guys are dead on with their recommendations on wiring. HPF needs to be on and around 80-90hz. As for speaker wires any decent 16awg wire will work for you.
snarl16
Audio Systems
05-30-2018 06:27 AM
JohnSWA
Audio Systems
08-20-2013 11:09 AM
yzergod
Audio Systems
05-20-2013 10:14 PM
BuckeyeRider
04-15-2010 07:49 PM
jskwarek
04-25-2008 08:11 AM
