Harness help XM - Hawg wired.
Old Apr 15, 2010 | 04:07 PM
BuckeyeRider's Avatar
BuckeyeRider
Default Harness help XM - Hawg wired.
I need suggestions / help.
I recently installed a hawg wired direct connect which added a harness behind the outter fairing. I have since added a XM module that came with a huge bulky harness with a bunch of plugs I'll never use.
My problem is 2 fold.
  1. I can barely get the outter fairing on trouble trying to find a place to tuck all the harnesses in and...
  2. When playing the XM it doesn't seem loud. I assume it is by passing the amp since it directly plugs to the back of the headset.
Is there a way to connect everything to get the Amped XM and eliminate all the bulk?
Thanks.
Old Apr 15, 2010 | 04:53 PM
Harleypingman's Avatar
Harleypingman
The XM harness uses only some of the 30+ wires in the 35 wire connector that you plugged into the back of the head unit. You could hack the fat harness (a/k/a non-Ultra overlay harness) and get rid of all the wiring you don't need, but that's not easy to do to a $100+ harness.
It may take you several tries but eventually you will find that by modifying the way the non-Ultra overlay harness is routed, you can fairly easily install the outer fairing. Getting as many of the unused connectors and used connectors tucked along the sides of the HK head unit seems to do the trick for me with the HK head unit, CB module, rider and passenger headset connectors, rear speaker connector, Arc 125.2 mini amp, and fairing lowers speaker wiring.
The XM signal is another source for the head unit like the CD. Anything played through the front speakers gets amplified because that's how your amp works: takes the signal that would go to the speakers and redirects it to the amp; and, then the amplified signal goes to the speakers. The amp doesn't care what the music source is since it's simply taking whatever comes from the headunit's speaker outputs, amplifies it, and sends the amplified signal to the speakers.
Carl
Old Apr 15, 2010 | 05:26 PM
BuckeyeRider
Thanks for the input. It just seems the sound level is much lower with the XM mode.
Old Apr 15, 2010 | 07:49 PM
Harleypingman
BR, in HD's 2006 Electrical Diagnostic Manual there is a test for XM that is providing low or no volume. It's Symptom 12 and there is a test protocol. You might stop by the local HD store and ask the service dept. to take a look at their book.
The test procedure calls for removing the outer fairing and connecting HD's "break out box" to test various connectors.
Good luck with finding a solution.
snarl16
Audio Systems
May 30, 2018 06:27 AM
scooter_nate
Audio Systems
Apr 6, 2018 09:10 AM
steelhead
Feb 6, 2014 09:35 PM
yzergod
Audio Systems
May 20, 2013 10:14 PM
Puzzled
Jan 1, 2009 05:25 PM
