EZ wiring?
Old Aug 17, 2013 | 07:09 PM
JohnSWA's Avatar
JohnSWA
Default EZ wiring?
Ok, so I followed the instructions and I blew out my Right speaker on my way to Sturgis. I don't know what the difference is with the Radio Sound stereo vs. the Harmen Karden but I followed the directions to a "T" since the only instructions are for a 07 and up. I have an 04. After buying another set of the Polk Audio mm651's, I still have the same problem with awesome sound out of the right speaker and lame, quite staticy major treble sound out of the left speaker! This has to be a wiring problem. I'm not complaining about the excellent "how-to" sticky thread, but there must be a difference between the "Radio Sound" stereos and the "Harmen Karden" stereos for wiring. I got to be missing something somewhere as I've double and triple checked my wiring!
Old Aug 18, 2013 | 08:32 AM
JohnSWA's Avatar
JohnSWA
Anyone?.... Bueller... Bueller?
Old Aug 18, 2013 | 01:45 PM
The Q's Avatar
The Q
Only thing I can think of is proper polarity between the two sides. Maybe one side is correct and the other is reversed. Just a thought.
Old Aug 18, 2013 | 02:03 PM
UltraNutZ's Avatar
UltraNutZ
hey john.. there is no difference in the wiring itself. The only thing different is the head unit but either one are just the same as for installation goes.
Can you take the speakers and connect them directly to the head unit speaker wires vs going through the amp? This will tell us if the amp is bad. Do not leave them connected to the head unit (only for test) and you'll likely not be able to get much volume because the head unit is looking for an 8ohm speaker and these are 2.7 ohms.
Old Aug 19, 2013 | 05:34 PM
JohnSWA's Avatar
JohnSWA
Thanks for all of your help. I believe I found the problem as I was confused as the original speaker color coded wiring matched the output wiring on the radio itself! I hooked the wires correctly to the imput side and the stereo rocks, but the left speaker is still very weak. I believe I have a bad amp. I also tried the original speaker wires to the new Polks and they both work perfectly, although very weak as they aren't hooked up to the amp!
Old Aug 19, 2013 | 05:45 PM
UltraNutZ's Avatar
UltraNutZ
just making sure I understand what you're saying here before we close this up.
if you connect the speakers directly to the head unit with the amp out of the picture altogether, the left speaker is still weaker than the right?
Old Aug 19, 2013 | 06:32 PM
JohnSWA's Avatar
JohnSWA
Negative. Both speakers have the same sound equally. I'm thinking it's the amplifier. What else could it be?
Old Aug 19, 2013 | 06:49 PM
UltraNutZ's Avatar
UltraNutZ
ah ok.. i misunderstood your post then.. onward then.. do you have a warranty on the amp?
Old Aug 19, 2013 | 07:32 PM
JohnSWA's Avatar
JohnSWA
I hope so! It's not even a month old! I left an email with RF and waiting on a reply.
Old Aug 20, 2013 | 11:09 AM
JohnSWA's Avatar
JohnSWA
Since I bought from Sonixelectronics, I have to go through them for the exchange. After speaking with them, I have to get approval for the exchange since it has been more than 30 days since I purchased the amp. They will let me know via email. Just another hassle. I'm glad I kept the original hogtunes speakers! Not the greatest but totally reliable!
trnewman
Audio Systems
Mar 7, 2016 07:42 PM
JoshuaCannon
Audio Systems
May 20, 2015 12:46 PM
Ryder7140
Audio Systems
Jun 1, 2013 05:13 PM
Beans HD
Jun 14, 2011 07:57 AM
999 Customs
Dec 5, 2010 03:19 AM
