troubleshooting speaker issue
Old May 18, 2015 | 06:09 PM
JoshuaCannon's Avatar
JoshuaCannon
Default troubleshooting speaker issue
Late last season I did the RF amp and Polk mmr651 speaker update on my 03 EGC. after a few days of riding I would lose sound. Possibly the amp shutting off? Then I lost the left speaker. I am troubleshooting my connections are fine and I placed the crossover and the wiring for the bad speaker to the good and all fine. So I'm looking at a bad speaker, correct?
Old May 18, 2015 | 11:33 PM
Little Mike's Avatar
Little Mike
That's what it sounds like. Since you didn't list a different HU I'm guessing you are still running the stock. If so does it cut out while you are listening to the radio, a CD, or an mp3 player plugged into the front jack? Or all of the above?
Old May 18, 2015 | 11:39 PM
Munkee's Avatar
Munkee
If you have a dmm you can also check if your polk reads 2 ohms like it should to be sure. But it does sound like you have already swapped wiring and found that the wiring to bad speaker does power on the good speaker meaning the amp is good.
Old May 20, 2015 | 12:46 PM
JoshuaCannon
Thanks guys. I will start looking for replacement speakers!
AZ_Breakout
Audio Systems
Jul 24, 2017 01:49 PM
nthere1
Jun 14, 2015 09:57 PM
SmittyFXDL
Audio Systems
35
Sep 27, 2013 06:59 PM
dapster
Audio Systems
Sep 18, 2013 10:25 AM
krom nutz
Jul 1, 2009 09:44 AM
