Install questions
Old Jan 16, 2018 | 08:58 PM
big- mike's Avatar
big- mike
Default Install questions
Well I'm starting to get some of my stuff hope to install this weekend. First question is should I plan on pulling new speaker wire? What do I use to wire from the hu to the amp (rz4.2000d) Igor the #8 wire covered from the battery to the amp.
Old Jan 17, 2018 | 04:57 AM
USAproud's Avatar
USAproud
16 gauge OFC wire for the speakers. And yes you will run all new wire to the speakers.
Old Jan 17, 2018 | 07:18 AM
big- mike's Avatar
big- mike
The reason I asked is I want to stop and pick up supplies and wasn't sure but I do remember seeing somewhere that 14 ga was recommended
Old Jan 17, 2018 | 08:20 AM
USAproud's Avatar
USAproud
14 might be a little over kill but will work
Old Jan 17, 2018 | 08:57 AM
SBates08's Avatar
SBates08
You'll wanna use 14 with those screw terminals on the amp. I use pre insulate ferules on the end of the speaker wire that attaches to the amp to keep the wire from breaking. A soldered end works too but will eventually break.
Old Jan 17, 2018 | 09:07 AM
USAproud's Avatar
USAproud
Where do you get those ferules from Bates?
Old Jan 17, 2018 | 09:14 AM
big- mike's Avatar
big- mike
Yep I noticed those lugs are pretty good size where is the best place to get 14 ga speaker wire?
Old Jan 17, 2018 | 09:32 AM
SBates08's Avatar
SBates08
Speaker wire can be bought lots of places local. Walmart, stereo shops, etc. I bought my ferrules from Amazon.
Old Jan 17, 2018 | 10:09 AM
big- mike's Avatar
big- mike
Ok thanks
Old Jan 17, 2018 | 10:51 AM
yooperhog's Avatar
yooperhog
Originally Posted by big- mike
Ok thanks
do you have a line converter to go from your head unit to your amp?
