Help!!!
Old Jan 29, 2018 | 10:16 PM
Parson2046's Avatar
Parson2046
Default Help!!!
Ok first off my bike is a 14 ultra limited. So I just installed a CV B54 and with a round of kappas 1 BT355 with a Y. 3 of the speakers sound great but 1 of them has very little sound coming from it. It started in the rear so I switched the wires around to see if it followed it to the front and it did. Any help guys would be greatly appreciated. Thanks Bill
Old Jan 30, 2018 | 05:08 AM
USAproud's Avatar
USAproud
If the problem followed the wire movement check all connections. Could be a loose rca or wire in harness plug. Could also be a bad channel on amp
Old Jan 30, 2018 | 08:09 AM
Parson2046's Avatar
Parson2046
Is there a way I can test the channel on the amp with a dmm?
Old Jan 30, 2018 | 08:13 AM
Tailwind's Avatar
Tailwind
What wires did u switch around?
T
USAproud's Avatar
USAproud
There may be a way but I am not sure. Are you using rca inputs to amp? If so try swapping those around and see if problem followed. That could point to bad cable or connection if it does follow
Old Jan 30, 2018 | 10:53 AM
Parson2046's Avatar
Parson2046
I switched the rear output with the front... I had an extra set of rca cables and switched them around also switched the Y adapters around...still the same
Old Jan 30, 2018 | 11:01 AM
USAproud's Avatar
USAproud
It always follows speaker or wire?
Old Jan 30, 2018 | 11:55 AM
Parson2046's Avatar
Parson2046
It's either the LR or the RF depending how the wires are.
Old Jan 30, 2018 | 12:00 PM
USAproud's Avatar
USAproud
Try running 1 set of rca from the line leveler to the front and see if it works ok. If it does move that set of rca to rear channels. If all 4 speakers work you could have a bad y splitter or rca cable set.
Old Jan 30, 2018 | 12:33 PM
Parson2046's Avatar
Parson2046
Cool thanks for the help I'll try that after work
