Quote:
i just used a dremel with cutoff / sanding. I used the inner groove as a reference & made the cuts. Make the speaker screw holes just slightly shorter than the grill.Originally Posted by Hoyt 1911A1
Hey Unit those look like the same Chinese grills I used on my lowers except yours have a chrome ring around them. How did you cut them down so clean and even? I got an extra pair to play with in case I ever wanted to use them on the rear or just get them to where they don't stick out quite as much.
