Audio upgrade install help and recommendations
#51
#53
That looks sort of like what I used Stache. It was Velco name brand. The issue I had wasn't that it would come loose. Because I was using the preamp inputs on the PN4.1000d I only had about 1/4 inch of clearance before something could short out. The Velcro allowed just a little bit of movement that I couldn't afford so I used the wire ties on the side to prevent that movement. Here is a photo of the clearance on the preamp side:
You notice that on the front channel plugs there isn't enough room to plug a factory RCA jack into. I had to create this:
In order to connect that channel. The power and speaker wires had about the same amount of clearance so I couldn't afford any movement. If someone were to use the speaker level inputs then there would be much more clearance and things wouldn't be as tricky.
Getting this amp into pre-Rushmore bikes takes a little doing sometimes but the payoff is pretty good for the money.
I’ll be using the rca inputs . Would the 90 deg. RCA adaptors not work. From pic can’t quite see how much space.
https://images.monoprice.com/product...ages/72331.jpg
Thanks ken
#55
Infinity has a new Kappa 6.5...the 62ix $130 on amazon..every Kappa has got better! The Soundstream 1000 D puts out 250 rms at 2ohms..stay on the low side with the gains if that's the path you choose! Kappas in the front ....Polks in the back should rock with that amp!
newmanb138
Audio Systems
16
06-10-2016 10:03 AM
