Help on system setup
Old Mar 13, 2018 | 01:53 AM
OUFanatic's Avatar
OUFanatic
6th Gear
Default Help on system setup
trying to decide on how to run everything I’ve ordered for my 2015 Street Glide. I have a Sony XAV-AX100 head unit. I have hertz sv 165.1’s and dd audio vo b3 horns for the fairing. Will have hertz 200.1’s and dd b3 horns for my twisted 8 lids. Looking to run the fairing on a diamond 4v2 and the lids on a SounDigital 800.4 4 ohm. Was thinking of bridging the fairing speakers and horns on the 4v2 and bridging the 200.1’s and horns on the 800.4 or is there a better way? Thanks in advance
Old Mar 13, 2018 | 01:03 PM
haze324's Avatar
haze324
you need an adjustable crossover or DSP to run the SD amp to any of those speakers. I also would never bridge horns on with 6.5's. You'll fry them.
Old Mar 13, 2018 | 01:50 PM
OUFanatic's Avatar
OUFanatic
6th Gear
I thought that’s what the crossover/bass blocker did on the back of the horn. Restricted the amount of power sent to them as well as allowing only a certain frequency to play or am I incorrect?
Old Mar 13, 2018 | 02:04 PM
haze324's Avatar
haze324
the capacitor is just a passive crossover. Your 6.5's can take significantly more power then you horns.
Old Mar 17, 2018 | 10:20 PM
DDUCK22's Avatar
DDUCK22
6th Gear
Default Where do I buy MMATS?
Haze,
I'm looking to do a MMATS set up in a 2018 RGS. This will not be for competition use but I want it to sound REALLY good. I want to run 601s with DD B3 horns (or MMATS horns if they are comparable) in the fairing and a DT 10 in each bag. I also plan on running a DSP but know which is better, the Arc PSM or the RF DSR-1. Are rear speakers needed to provide highs in the rear or can i get by w/out them? Thinking about running 2 MMATS D4100s. Problem is i have no idea where to buy MMATS. I live in Columbia SC
I'm completely open to any suggestions or advice you have.
Thank you in advance
Old Mar 17, 2018 | 11:03 PM
haze324's Avatar
haze324
I’m sure someone will PM you offering to sell you some.
Old Mar 18, 2018 | 12:29 AM
OUFanatic's Avatar
OUFanatic
6th Gear
Originally Posted by DDUCK22
Haze,
Check out Badd Azz Bikes in Temple Texas. They sell MMats audio. Anthony and Cameron both helped me out when I ordered
Just wanted to thank you as well haze. Ditched the SounDigital and went with 2 diamond 4v2 amps. Won’t have to mess with the DSp now.
Old Mar 18, 2018 | 08:06 AM
Tailwind's Avatar
Tailwind
Haze,
Have you heard this setup in person?
T.
Old Mar 18, 2018 | 10:37 AM
DDUCK22's Avatar
DDUCK22
6th Gear
T.
I have not. I really havent heard a system on a Harley other than front 6.5 with bag 6x9. Harley stereo is not big here in Columbia SC.
I have only heard YouTube videos
Is this not a good set up?
troop
Audio Systems
11
Apr 25, 2019 07:41 PM
cshocker
Audio Systems
18
Apr 10, 2019 07:41 AM
Clayton24
Audio Systems
52
Feb 21, 2019 11:32 PM
yogi580
Audio Systems
Jan 12, 2018 09:34 PM
Tailwind
Audio Systems
11
Apr 8, 2016 09:57 PM
