Frustrated
Old May 2, 2018 | 07:37 AM
Brent Michael's Avatar
Brent Michael
Default Frustrated
Hey guys. I'm about ready to tear all this crap out and go back to factory. 08 ultra. Kdc x998 head unit. Rockford t400x2ad amp powering hybrid audio image 6.5 speakers. Everything hooked up gains set. Everything sounds good and loud in driveway. Put fairing back together go for a ride and the speakers can barely be heard. Rears that are only powered by hu are loud. I've changed rca checked grounds and am about out of patience. Any ideas?
Old May 2, 2018 | 07:43 AM
Brent Michael
Default Frustrated
Btw. Running those same speakers off the factory hu with a hawg wired 150 watt amp sounded good but i was told the hats needed more power than that which is why i switched.
Old May 2, 2018 | 07:52 AM
InthewindMN's Avatar
InthewindMN
When you are listening to it in the driveway is the bike running? When you say you can’t hear it going down the road is that just at speed or are they quiet all the time? Different between running and in accessory?
Old May 2, 2018 | 08:00 AM
Brent Michael
Default Frustrated
Yes running in driveway with the rpms up to 2k. On highway they're just quiet. The rears are the only i can hear unless i duck behind shield and the fronts are still very low.
Old May 2, 2018 | 08:16 AM
travelingypsye's Avatar
travelingypsye
It has to be a connection problem somewhere. Don't think its a remote wire problem as there would be no sound if the amp isn't on. Its not one of the speaker connections as the other would work. How do you have the amp grounded?
Old May 2, 2018 | 08:26 AM
Brent Michael
Default Frustrated
Grounded to battery. Tried d different rca's
Old May 2, 2018 | 08:31 AM
travelingypsye
Good on the ground. That was my next suggestion. RCA connections are the industry standard but I hate them. I would also try wiggling all wires while the fairing is off and the bike is running to see if it happens then.
Old May 2, 2018 | 08:37 AM
Brent Michael
Default Frustrated
Yep did that. Put on fairing. Still loud. Hop on bike head down road and it sucks.
Old May 2, 2018 | 08:44 AM
InthewindMN
do you feel like the sound output changes when you start moving or is it that your not hearing them as much due to wind noise?
Old May 2, 2018 | 08:50 AM
Brent Michael
Default Frustrated
Definitely not wind.
