PRV 6mb250-NDY
Actually funny you should ask that question T about using these speakers in the stock pods on a batwing.
I did a install for buddy on his bike with 4 of the PRV 6MB250NDY a set of DD T2 tweeters ,linelevler and a Diamond 4v2.
Here is a video of the setup.
https://www.dropbox.com/s/sm9dumksps...51346.mp4?dl=0
What line levelers did you use and how was the amp set up? I had a similar setup and was unhappy with it but maybe it was just a tuning issue.
If you are having issues tuning and feel like taking a ride one Saturday or Sunday you can swing by as you are not that far from me.
The linelevelers are very sensitive when making adjustments so if you have moved the pots it will have to be reset.
you dont happen to remember those line leveler settings or the procedure do you?
The procedure can be long a tedious and you need the correct frequencies with the correct db to get the settings correct. All the settings are in millivolts from Biketronics so you will need an accurate DVM and a steady hand.
