2 ohm 4 ohm help
Old Jul 21, 2018 | 12:24 AM
cmashark's Avatar
cmashark
Default 2 ohm 4 ohm help
So a couple days ago I installed a Sony xav-ax100 stereo and a set of infinity kappa 62.11i speakers in my Road Glide Special. So far, it’s better than the stock set up. My bike isn’t very quiet and I typically have my volume set around 36 or 37 when at 60mph and above. With the EQ set to the “rock” setting and the bass boost set on 2, I get crazy distortion at 41. With the base boost off, I don’t get the distortion until 46 or 47. It sounds awesome with the boost on, before I notice the distortion and good with the boost off.
now, I know this stereo doesn’t put out enough power to really drive these speakers to their full potential. What has me concerned is that my friend, while not an audiophile, he noticed that my stereo’s is 4-8ohm and my speakers are 2 ohm. What am I about to tear up and what is the best way forward?
Thanks in advance!
Chris
Old Jul 21, 2018 | 12:31 AM
mmesa005's Avatar
mmesa005
I too am not an expert but this reflects my understanding
https://www.hdforums.com/forum/audio...-speakers.html
Old Jul 21, 2018 | 01:56 AM
Sturgis67's Avatar
Sturgis67
First things first. You need an amp. PERIOD! From what I see you are running a head unit and speakers with no power. Distortion is the norm without an amp. Add some power and you will be much better off . Tons of info on this site on amp recommendations, and tons of great dudes to help you out.
Old Jul 21, 2018 | 07:51 AM
Babyboy's Avatar
Babyboy
Rule of thumb is you can go up with speaker resistance but dont go down as it will overwork the amp/headunit and possibly let the magic smoke out.
I would suggest getting yourself an amp to get the volume you are looking for when riding.
Post up a budget for and amp and we can suggest one suitable for your setup and future expansion
Old Jul 21, 2018 | 07:56 AM
Juice's Avatar
Juice
a cerwin vega b54 while not the best SQ amp, for the price it will make those Kappa come to life. You got a good deck now let the beast come to life.
Old Jul 21, 2018 | 07:46 PM
cmashark's Avatar
cmashark
Thanks for all the replies. I do all of my own mods, but don’t know much about stereo systems.
I was looking at this amp:
https://m.ebay.com/itm/FOCAL-SOLID2-...from=R40&rt=nc
also,when I ordered the stereo, volunteer audio mentioned a small $170 amp that would work. I wish I would have asked what brand and model it was.
Just to make to make sure, if I add an amp that will run the 2 ohm speakers, the 4 ohm stereo wont be a problem?
Old Jul 21, 2018 | 07:52 PM
cmashark's Avatar
cmashark
i don’t have a budget. I don’t want to spend a fortune and just want it one and done. I don’t plan on adding bag speakers. 2 channels are all I need.
Old Jul 21, 2018 | 08:04 PM
cmashark's Avatar
cmashark
Im looking that up now... thank you!
Old Jul 21, 2018 | 08:12 PM
Ndfastln's Avatar
Ndfastln
If you only need 2 channels then go or the Cerwin Vega B52. It has always been a good match with those kappa's and cheaper than the B54. Not to mention smalller and easier to fit.
https://www.sonicelectronix.com/item...SABEgKgAPD_BwE
Old Jul 21, 2018 | 10:06 PM
cmashark's Avatar
cmashark
I notice the RMS of that amp at 2 ohms is 250 and the RMS for the kappas is 75 with 225 as the peak. That’s ok?
